Author Topic: MAX17710 Charger and recommended battery  (Read 2325 times)
Offline GoatureTopic starter
  • Country: no
« on: February 02, 2016, 10:41:33 am »
Hello all!
I'm having fun with the MAX17710 Energy-Harvesting Charger and Protector. The IC is designed to charge a 4.1V rechargeable cell, and the datasheet specifies the Thinergy MEC200-series as a suggested battery. I have not been able to find this battery for sale, at any of the common distributors. Do you have any suggestions to what replacement I can use?
Ps. The datasheet specifies that the cell has to be a "low-capacity cell", but that doesn't tell me much. Im therefore not sure, if a single cell LiPo will be too large. The Thinergy Batteries are <3mAh.
Tinergy MEC201:
4.1V
1mAh
350uA discharge
30mA Max discharge
1"x1"x0.01"
« Last Edit: February 02, 2016, 11:01:24 am by Goature »
  • Country: no
Re: MAX17710 Charger and recommended battery
« Reply #1 on: February 03, 2016, 08:22:09 am »
For anyone interessted, I managed to find the following:
EFL700A39 from STMicroelectronics (0.7mAh)
PGEB201212 from PowerStream (10mAh)
CBC050-M8C from Cymbet (5uAh)
Online amyk
« Reply #2 on: February 03, 2016, 11:59:06 am »
According to the datasheet, this charger charges at 625nA, or 0.625uA. That is a tiny amount of current. At that rate, even a 5uAh cell will take 8 hours to charge. I doubt a larger cell would even charge, because its self-discharge will far exceed that. For comparison, the protection circuitry of a regular lion cell continually draws a few uA, which is several times more than the charge current this IC can put out.
To give a perspective on the order of magnitude, a typical 18650 of ~2000mAh capacity would theoretically, ignoring leakage and other losses, take over 365 years to charge at that current.
« Last Edit: February 03, 2016, 12:02:44 pm by amyk »
  • Country: no
« Reply #3 on: February 03, 2016, 08:57:11 pm »
It might be me that is misunderstanding, but the value you are referring to is the quiescent current (I_qchg) of the charger when active. Some might call this value the "leakage current". The charger actually has a typical charging current rated to 100mA (CHG Maximum Input Current). Limited by other maximum ratings of course.
Can anyone confirm this?
« Last Edit: February 03, 2016, 08:58:53 pm by Goature »
Offline sleemanj
  • Professional tightwad.
« Reply #4 on: February 03, 2016, 10:02:19 pm »
I concur,
CHG Continuous Current
 (limited by power dissipation of package) ...................100mA
CHG Quiescent Current IQCHG VCHG = 4.0V rising, VBATT = 4.0V 625 1300 nA
