Author Topic: off the shelf industrial 5W AC/DC module  (Read 882 times)
Offline ali_asadzadehTopic starter
« on: June 18, 2019, 12:13:27 pm »
I want a 220V AC range input, 5W 12V output -40 ~ 85c operating miniature AC/DC module, digikey has some parts, but they are a bit pricey and on the low stock, Do you recommend something?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline BravoV
  • +++ ATH1
Re: off the shelf industrial 5W AC/DC module
« Reply #1 on: June 18, 2019, 12:15:08 pm »
Aliexpress
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: June 18, 2019, 01:10:07 pm »
"Cheap", "industrial". Pick one.
Seven Transistor Labs, LLC
Online SiliconWizard
« Reply #3 on: June 18, 2019, 01:28:33 pm »
What would be your target price per 100? Per 1000?
The RECOM RAC05-12SK is relatively cheap, it's dependable and there is reasonable stock at Digikey: https://www.digikey.com/product-detail/en/recom-power/RAC05-12SK/945-3117-5-ND/7603370
(there's never going to be thousands of pieces of stock for this kind of parts, if you need more, you'll have to ask). Were you expecting to spend less than a few dollars on such a module?
Edit: just realized it's rated up to 70°C only, whereas you're targetting up to 85°C. Is this requirement mandatory? If so, I can suggest the Meanwell MPM-05-12, which is even cheaper. Meanwell may not be as good as RECOM, but that's still decent.
« Last Edit: June 18, 2019, 01:34:51 pm by SiliconWizard »
« Reply #4 on: June 18, 2019, 01:33:01 pm »
Industrial then!
LS10-13B12SS from mornsun seems nice,
https://www.mornsun-power.com/uploads/pdf/LS10-13BxxSS.pdf
Do you recommend them? are they reliable?
Offline XaviPacheco
  • Country: do
« Reply #5 on: June 18, 2019, 02:17:09 pm »
Industrial then!
Where would you buy them? What's the price? I couldn't find it. I have used RECOM modules, and I recommend them.
