Hey guys, new here, but been into electronics for a fairly long time. One downside to this is I was always self taught - so I know the practical side of it very well, but suck at the theory!
I have a cheapo weather station, and keep having issues with it dropping out! It's outdoor sensor is wireless, and is almost line of sight out the window, but still!
I have opened up the receiver once, and tried replacing the antenna wire with a longer one of a precise length, however it doesn't seem to help. It says it's nominal operating frequency is 433MHz, pretty common, but I can't tell for sure as I have no way of measuring!
Could someone possibly help me out with calculating the antenna wire lengths for this frequency? I would prefer to not have to make it directional, but I suppose it's not out of the question.
EDIT: The wire I have on it now seems to be about 30cm, which looks like the half wavelength. Originally it must have had 1/4 wavelength, but going to 1/2 didn't seem to help ... maybe even made it worse!
I must also note that there are water tanks between the RX and TX, however it is not very large at all, I can almost just see the sensor setup from out the window the RX is sitting on. Is it possible the water is interfering?
Cheers,
Dan
If it has a 1/4wave antenna mounted on the unit,extending it to 1/2 wavelength is not going to help,& indeed may make things worse.
End fed antennas of different wavelengths present widely differing impedances to the device they are connected to,with mismatched impedances causing loss of signal.
One thing you can try is hanging a 1/4 wave wire off an "earthy" part of the receiver.
This is often used with Handheld VHF & UHF Ham radios to improve the performance of the antenna,
If your antenna is a screw on type using an SMA connector,you can probably connect this wire to the outside part of the connector,otherwise you may have to take "potluck" at finding a earthy point on the receiver body.
If the water tank is metal,it could be shielding your antenna from the signal,whether it has water in it or not.
If it is plastic,it should not shield much,unless it is full of water.
Another possibility is that you are getting two out of phase signals at your antenna which are cancelling.
One could be direct,& the other reflected or diffracted by the tank or something else.
Is the receiver portable?
If you can take it up close to the sender,& see what results you get.then walk around to see where it starts to get dodgy,you may be able to find a better position for it or the sender.
If the receiver is not portable.can you move the sender around in the same manner?
