Author Topic: LED boost driver in DIP package  (Read 3074 times)
Offline PeterFWTopic starter
    • Stuff that goes boom
« on: June 22, 2016, 12:42:09 am »
Hello!
My google search was not that successful, so i ask here in hopes such device may be still exist.
I had a silly idea for a small project that would require a LED boost driver that is available in a DIP package to run 4-8 white LEDs (~3V@100mA per LED) of a lithium cell.
Why DIP? I want to spare me some work milling out a regular package and epoxy an smd device in there, to have an authentic working circuit like this:
Picture:
http://3.bp.blogspot.com/-1kZFCTevyxA/UQJuhvCqlaI/AAAAAAAACLQ/kfOgjQfbsk8/s1600/IMG_3393+(Large).JPG
Website:
http://runawaybrainz.blogspot.com/2012/04/audio-crystal-cmoy-freeform-headphone.html
Why? I got to use the left over resin i have for something, this came to mind.
Greetings,
Peter
Offline mariush
Re: LED boost driver in DIP package
« Reply #1 on: June 22, 2016, 02:18:10 am »
100mA per LED is a lot of current, are you sure the LED will stay cool inside all that resin?
4-8 LEDs at 100mA each is 400-800mA .. again, that's a lot of power.
See TLC5917 , seems like a good chip : http://uk.farnell.com/texas-instruments/tlc5917in/ic-led-driver-linear-16-dip/dp/1755252
You'll have to program it somehow, so maybe also add a 6-8 pin micro just to initialize the chip through SPI and turn on the channels?
« Reply #2 on: June 22, 2016, 02:35:50 am »
I have played with LEDs a bit, i think it should work out:
https://www.eevblog.com/forum/projects/solution-for-single-color-tubular-led-display/msg859222/
The 100mA is just for short periods, most likely it will run on much, much less.
The whole thing will have a micro in there as well, the micro got a ADC and i planed to use that to measure the resin temp near the LEDs as a fail safe.
See TLC5917
Thanks, i was thinking more of a switched single channel driver with an efficiency around 85% and put all of them in series.
So about 12V to 24V at 100mA for a series sting.
Found many suitable drivers, but all SMD, i will just use one of them if there is no DIP but i wanted to at least try to use real DIP packages :)
Greetings,
Peter
« Last Edit: June 22, 2016, 02:37:22 am by PeterFW »
Online georges80
« Reply #3 on: June 22, 2016, 05:13:07 am »
Simple answer is that no modern IC's are going to be available in DIP - no demand since pretty well everything has moved to surface mount.
So, other than antiquated chips you're essentially out of luck.
Even 4 series LEDs are going to be around 4 x 3V = 12V and at 100mA you have 1.2W at the output. I presume you mean lithium ion cell and not a coin lithium cell...
cheers,
george.
Offline chris_leyson
  • Country: wales
« Reply #4 on: June 22, 2016, 06:55:22 am »
I think you're going to out of luck finding LED drivers in DIP packages. Maybe a SOIC to DIP adaptor would work but finding one with an addition thermal pad and with a small DIP sized footprint isn't easy.
« Reply #5 on: June 22, 2016, 07:35:15 am »
Indeed, i allways get the right term mixed up since english does not translate well in my head sometimes :)
I will just bodge some small package in there, can not be much more difficult then a SSOP dead bug.
Offline dannyf
« Reply #6 on: June 22, 2016, 10:55:46 am »
There are some thin film sip orr dip dcdc converters - some Japanese companies make them.
Putting that so close to audio circuits isn't a great idea in my view.
Online Fungus
« Reply #8 on: June 22, 2016, 01:15:27 pm »
I just had a thought: You could maybe use AN6884. Each chip will sink about 85mA by tying all the pins together and they're easy to switch/PWM from a micro.
The disadvantage is that you need one chip per LED, but... hey: They're SIP packages so you can pack them tightly, arrange them artfully... whatever.
« Last Edit: June 22, 2016, 03:46:30 pm by Fungus »
Offline Galenbo
« Reply #9 on: June 22, 2016, 01:46:39 pm »
I use ULN2803A to drive 8 relays, up to 500mA, DIP
http://www.ti.com/lit/ds/symlink/uln2803a.pdf
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
« Reply #11 on: June 22, 2016, 02:40:30 pm »
Do the DIP yourself
But that does not look like a DIP package, im searching for dip because of the look, not because i can not solder it.
Wiring a MSOP with enameled wire or etching a PCB is totally within my comfort zone and capabilities :)
What about the old  guy 555
If your OK with a micro.
Oh... i had not thought of this. Thank you very much, that is spot on!
Saves me additional components and looks cool, exactly what i was aiming for.
Will have to do some further reading on that!
