The plugs are unplugged and the power is off. The resistance/load is on the other end of the harness and should be present. The conundrum is that I can not use the external access points (A, B & C) to take a reading; the last time I performed this same test what I am describing worked and now it doesn't.
Worse, I can not get a continuity reading from any one of the access points to either the wire on the left or the pin on the right.
FTR, I'm a long time computer geek; networks, board level fixes, programming in multiple languages and otherwise a jack of all trades/and, as the saying goes, master of none.
This just has me stumped and it's the reason I registered on this forum.
I'm going to set up this test again in an hour or so. I'll let you know what I find, even if, as I suspect, I've made some false assumptions.
Many thanks, Nick
