Author Topic: Voltage Inverter?  (Read 2274 times)
Offline negativ3Topic starter
  • Country: th
Voltage Inverter?
« on: October 13, 2015, 10:14:02 am »
Hi all,
I have a linear sensor which acts like a pot in that +24V supply across it gives an output 0-2.5V at the wiper.
Is it possible to invert the output (somehow) so that it runs 2.5V to 0V instead of 0 to 2.5V?
So 0V out of the sensor I want 2.5V and 2.5V out of the sensor I want 0V.
I have tried reversing the supply however the sensor must have some built-in clamping going on to prevent reverse supply connection.
http://www.regal.se/data/prodfile/ktc_ktf_ktp_en_2015.pdf
Many thanks.
« Last Edit: October 13, 2015, 10:19:52 am by negativ3 »
  • Country: th
Re: Voltage Inverter?
« Reply #1 on: October 14, 2015, 02:22:39 am »
Thanks blueskull.
Offline mikerj
« Reply #2 on: October 14, 2015, 10:02:03 pm »
The datasheet suggests the sensor can either be supplied as a simple potentiometer or with a 4-20mA output.  If you have the basic potentiometer model, why are you only getting 2.5v maximum at the wiper with a 20v supply?  Do you have the 4-20mA version?
  • Country: th
« Reply #3 on: October 15, 2015, 12:58:55 pm »
Good question mikerj, I shall confirm what is here with a meter in series with the output.
Offline mikerj
« Reply #4 on: October 15, 2015, 09:28:59 pm »
You could just read the model code of the device (assuming it's readable/still present) and check against the datasheet.
  • Country: th
« Reply #5 on: October 25, 2015, 06:50:18 pm »
Turns out it indeed is a 4-20mA output. Good call. No label available unfortunately.
