Author Topic: Trip Amplifier Circuit  (Read 1454 times)
Offline andybarrett1Topic starter
« on: October 24, 2015, 08:52:19 pm »
Hi All
Thank you for reading .... I have a need for a simple Trip Amplifier circuit .... They used to be all over the industrial world ... But not so much now !
Basically something that looks at a 4-20ma signal and trips a low or high relay depending on my set points. I am at this moment thinking of using a 339 comparator and a couple off bc108 driven relays.
But. I was wondering if anybody had any better ideas or maybe a PIC controller might  do job better ?
I am open to any thoughts .... thank you for reading
Andy
Offline Marco
Re: Trip Amplifier Circuit
« Reply #1 on: October 24, 2015, 10:00:22 pm »
Still quite a few new trip amplifiers for sale, mostly in Britain for some reason.
Could use a TL431 with that BC108 as well.
Offline Seekonk
« Reply #2 on: October 25, 2015, 07:26:40 am »
A  TL431 is a great choice if you like component level building.  These easily drive small relays by themselves if a dry contact is needed. I am getting spoiled by those Arduino clone mini328 boards that can be bought for $2-3 for these small jobs.  If a switch transition at a set voltage was all you wanted, life would be simple.  When you add in time delays and hysteresis a small micro wins hands down.   In my opinion spending 75 cents more for the gold boards is worth it.
« Reply #3 on: October 25, 2015, 09:08:10 pm »
Hi
Looking at the TL431.... But it looks a little sensitive  :-//
BR
Andy
