I disconnected the front panel from the back to get a closer look and this is what I got. I have not had a chance to do any work on the pinout but I thought these pictures might be helpful. Grand Total Count is 1x each: DTL NAND, DTL NOR, TTL 7490 Decade Counter, TTL 7404 NOT, LM709 Op amp; 2 each: AD308 op-amp , 7474 TTL D-Flop 1 on front board 1 one on back, LM555 Timer, CMOS 4016B analog switch; 3 each TTL LED TIL306 counter decoder.
In total I am guessing this might be a autoranging V/F based panel meter, probably the AD308's are analog, the LM709 is used as comparator? on the bsack of the front board is 71-0569505 and on the back of the back board is 71-0618803. Any ways, thanks!
