Author Topic: ZVS Induction heater 2000W 40A 50V  (Read 53989 times)
Offline RolingStones
  • Country: ru
Re: ZVS Induction heater 2000W 40A 50V
« Reply #25 on: October 03, 2018, 08:45:07 am »
Looks impressive and well build
May I ask if you if you have tried using litz wire for heating coil instead of the copper tube? I have been working with a smaller 1000W ZVS drive and trying to optimize the electrical hysteresis by heating an iron pipe (high ferromagnetic material). Using a copper tube as heating coil the iron (Fe) heats faster than when using a litz wire. Theoretically it should be the other way around.
  • Country: ru
« Reply #26 on: October 08, 2018, 06:52:38 am »
Lepel RF generator is something new for me, is it using vacuum tubes? Do you have schematic?
I am planing to build mains powered PLL induction heater. I am aiming on about 3kW power
Were you able to design the 3kW? I would be very interested in seeing it in action.
Offline SharkyJr
  • Country: eg
« Reply #27 on: October 13, 2018, 02:44:39 pm »
Hey thanks for sharing this! Im a beginner in Electronics and i wanted to know what should be the power rating of the resistors? I noticed in the order history, you shared on Drive, that the 1k and the 10K are 1/4W but no info on the other ones.
Offline aamirchef135
« Reply #28 on: November 26, 2018, 08:01:28 pm »
Where I can buy it and how much please
Sent from my SM-G935F using Tapatalk
Offline DR Martin
« Reply #29 on: December 07, 2019, 12:53:21 pm »
Do you have the Altium source files for you rev. 2 board with protection?
Offline krul_serwisu
« Reply #30 on: April 23, 2020, 08:30:32 am »
Hello,
Could you tell what is the gauge of the wire you've used to make the inductors? As I've seen there are 32w of 4-wire wick.
