Howdy,
I have custom PCB design with SAMD21G and 2 separate I2C (feather M0 bootloader).
I wrote code to scan both I2C lanes and uploaded to MCU – second I2C port (that I created) scan finds chips just find, but no devices on 1st I2C port (there are 3 devices with different addresses on that port). I also used default I2C scanner code that scans only default I2C port – same result, no devices.
And here is the interesting part – If I connect another I2C device with its own pullups – ALL devices just appears in the scan until I disconnect it and they disappear again. You may say it's pullups, well, just keep reading....
I have another SAMD21G bare breakout board with only necessary components, if I jumpwire it to the same I2C lanes (with pullups only on custom PCB) and scan – it detects those devices just fine (with no additional I2C device and no extra pullups). Pullups on that line works fine, I used 10K resistors pull to 3,3V.
Also that SAMD21G on the PCB doen't react to RESET going low (internally pulled up), at least computer doesn't make USB connect/disconnect sound (other SAMD21G break out board do).
I'm thinking this is cos of one of two things:
1. some SAMD21G pins are pulled up/down by the PCB design that shouldn't be and messes with reset
2. I did an oopsie on PCB design – one chip (on 2nd I2C port that works) uses interrupt pin, and I missed that this chip sends 5V instead of 3,3, so that MCU got 5V. After realizing this I disconnected that pin and tested – that interrupt pin on MCU seems to work fine still.
Eventually I will solder jump wires and connect pin by pin to breakout board to find out what is the issue, but as you can imagine it's very tedious task, so I just posting my issues in hope to get some ideas before I do that. Sadly I just can't change MCU – I don't have hot air station.
I little update: I figure I'll try to add another I2C device (with no pullups on it this time, pullups only on PCB), and "bad" MCU on the chip sees it, but this time it detects only that chip, it doesn't detects other 3 chips on the PCB. I tried again another I2C device with its own pullups – all chips gets detected. WTH...
Cheers
