I'd like to build a multichannel manometer for adjusting combustion engine intake vacuum, 2, 4, 6, or 8 cylinders.
I plan to use an Arduino, but not sure if there are any inexpensive pressure/vacuum transducers that would work for this application?
The ones I'm seeing on digikey are a bit more expensive (~ $12 to $26 each) than I'm hoping to find. Is there a less expensive way to make this kind of sensor (other than typical mechanical dial gauge or liquid column)?
