Author Topic: Homemade spot welder keeps blowing MOSFETs  (Read 14304 times)
Offline costi_b
Re: Homemade spot welder keeps blowing MOSFETs
« Reply #50 on: April 22, 2024, 06:25:43 pm »
I used 9 pieces P140LF4QL-5071, Housing
LF (similar MO235B), 140A 40V, driven by a TC4422, 4R7 in each gate, mounted on an aluminum PCB. I have recovery diodes between drain and +.
As a power source I use a 12V 100Ah gel battery connected by 16mm2 cables in parallel with a capacitor pack of approximately 0.6F.
The soldering cables are 6 mm2, flexible.
I've done several hundred welds in this setup, the only thing that gets hot are the welding leads. I use about 30ms welding time.
Offline RefrigeratorTopic starter
  • Country: lt
« Reply #51 on: May 09, 2024, 11:37:38 am »
Yeah i noticed 6mm2 get a bit hot if you're welding fast enough.
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
