Author Topic: Rant: D Connectors  (Read 3350 times)
Offline German_EETopic starter
Rant: D Connectors
« on: June 18, 2017, 03:25:01 pm »
The situation with D connectors really bugs me. Most of the world (including the IC manufacturers) live in a 0.1 inch x 0.1 inch world and everything fits in here from displays and chips to a large number of connectors. Not the D type though, that second row of pins offset from the first means that you have to either make your own PCB or use an adapter. When making a PCB mounted socket or plug it would have been just as easy to make the pins on a 0.1 x 0.1 grid, just bend the wires a bit, but they just couldn't do it.
OK, rant over, I have 12 holes to drill between the existing holes on a piece of perfboard.
Warren Buffett
Offline Alex Eisenhut
  • Place text here.
Re: Rant: D Connectors
« Reply #1 on: June 18, 2017, 03:26:44 pm »
That's why you use an IDC connector that uses ribbon cable to go to the board, perfectly fine grid there.
Offline Gyro
« Reply #2 on: June 18, 2017, 03:33:08 pm »
If you can put up with mounting the D-sub connector at the edge of the board, then you can solder one row and hand wire the other one. I've done it for small RS-232 adaptors in the past. Just a thought.
Best Regards, Chris
Offline N2IXK
« Reply #3 on: June 18, 2017, 06:53:53 pm »
The D-subminiature connector line dates back to 1952, well before the DIP package that ushered in the 0.1" grid standard.
Not sure why you would expect it to conform to a standard that didn't yet exist...
"My favorite programming language is...SOLDER!"--Robert A. Pease
The following users thanked this post: fourtytwo42
Online floobydust
« Reply #4 on: June 18, 2017, 07:32:16 pm »
So you prefer micro-USB? SNAP BREAK BUST FAIL
The following users thanked this post: Electro Detective
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: June 18, 2017, 07:56:50 pm »
Centronics style connectors have arbitrary dimensions.  GPIB for instance isn't apparently metric or imperial, it's just odd.
Doesn't matter when you've got PCBs.  Doing perf board?  Put it on pigtails... :-//
Seven Transistor Labs, LLC
Offline Someone
    • send complaints here
« Reply #6 on: June 19, 2017, 01:58:40 am »
No, the world has moved on from those days. Metric is now driving pin pitches 0.7, 0.5, 0.4mm so on and through hole is disappearing rapidly.
Offline DBecker
« Reply #7 on: June 19, 2017, 04:58:09 am »
I think that the original poster's point was that the PCB footprint doesn't necessarily need to match the connection pin pitch.  It would be useful to have a D-shell connector that has a 0.1" footprint.
The following users thanked this post: Jacon
Offline Vtile
  • Ingineer
« Reply #8 on: June 19, 2017, 08:49:45 pm »
Long live D-sub.  :)
Online Andreas
« Reply #9 on: June 19, 2017, 09:10:15 pm »
Hello,
I cannot complain: My D-Subs fit. Always.
with best regards
Andreas
The following users thanked this post: Someone, Smokey, Electro Detective
Offline viperidae
« Reply #10 on: June 20, 2017, 06:47:54 am »
RJ11/12/45 sockets are the same, two rows of offset pins that won't fit a perf board.
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
« Reply #11 on: June 20, 2017, 08:28:39 am »
I think the flawed assumption here is that the potential advantage of having a connector (or anything really) fit a .1" perfboard outweight all the other advantages of not having it fit - like how easy it is to route on an actual pcb, strength, density, etc.
Also, most manufacturers no longer live in a imperial-driven world. The only things really still imperial (but actually it's not) is SMD footprints like the typical "1206, 0805, 0603, 0402" (even though I believe they are actually defined in metric and then translated to imperial to match, with a 0402 actually being 1.000mm long and 0.500mm wide). In fact, I usually get annoyed by the old DIP footprints and headers not fitting nicely on my metric grid PCBs, making nice allignment a PITA.
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
