Author Topic: lm78xx series question and some more stuff  (Read 1557 times)
Offline KilroywashereTopic starter
  • He has the stink of oil and electric circuitry...
« on: January 23, 2020, 12:47:23 am »
Hello world,
I'm building a lab power supply and I only have 1 Lm317, I want to have a current limit of up to 1 amp . I know that you can use a 78xx series to provide a constant output current, I was wondering can I just use a 7805 as my current regulator or will 1 amp be too much for this thing to handle ? (get super hot and such) I wanted to save the Lm317 for the voltage adjustment, or is it better to use it for current if you only have one?
Also some designs I look at have two 1n4001 diodes and a transistor leading into -10volts  (I guess to bring the output to 0 v?) is it better to have  some sort of duel  + - power rails powering the thing?
He is part of the dead...he has no place here. He has the stink of oil and electric circuitry about him. He is obsolete...
Offline Vovk_Z
  • Country: ua
Re: lm78xx series question and some more stuff
« Reply #1 on: January 23, 2020, 07:27:11 am »
- yes.
The following users thanked this post: Kilroywashere
Offline MarkF
« Reply #2 on: January 23, 2020, 01:05:36 pm »
Do you want to just limit the current to 1A or do you want an adjustable current limit?
If you want an adjustable current and are okay with a minimum of 1.2V of the LM317,
you can do something like this:
If you just want a fixed 1A current limit,
take a look at this battery charger circuit:
The sense resistor value can set a fixed current limit with the minimum LM317 voltage output.
You will probably want a full-wave bridge and a large cap for the input.  But you get the idea.
(You can use any NPN transistor, 2N2222, 2N3904, etc.  But will need to select a different sense resistor value.)
913312-0
You only need a negative if you want to pull the minimum output voltage down to 0V.
« Last Edit: January 23, 2020, 01:10:13 pm by MarkF »
The following users thanked this post: Kilroywashere, WattsThat
Offline MarkF
« Reply #3 on: January 23, 2020, 01:13:43 pm »
A LM317 circuit that goes down to 0V.
