Author Topic: Op Amp Triggers When It's Not Suppose To  (Read 604 times)
Offline epicodeTopic starter
  • Country: il
« on: November 11, 2019, 12:31:49 pm »
Hello, I've been working on a boost converter for a long time now and my control system needs to provide two high frequency inverted signals (when one is high the other one has to be low) and I've been using two comparators for that, both of them get a voltage reference (some constant DC voltage) and a triangle wave just that the inputs are swiped so that the required signal can be generated but for some reason the two signals are phase-shifted like the attachment below, I've checked the triangle wave and it is in perfect sync in both inputs.. the op amp is OPA2691I and as you can see in the picture the op amp seems to trigger in a weird way.. any ideas ?
Modify message
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Op Amp Triggers When It's Not Suppose To
« Reply #1 on: November 11, 2019, 12:51:24 pm »
I am sorry but you can't have two identical topics: https://www.eevblog.com/forum/beginners/dual-comparator-output-is-phase-shifted/msg2779672/#msg2779672 this will just annoy people. Please only post your topic once.
