Author Topic: OpAmp for high-Q inductor in ultra-narrow band notch filter in controller applic  (Read 1523 times)
Offline ricko_ukTopic starter
Hi all,
I'm trying to filter out a "single" frequency (200 KHz). i.e. a ultra narrow band pass filter. It works quite well using a simple high-Q LC filter but with the inductor and capacitor tolerances it is hard to tune it to that exact frequency and I need it to be very precise. I have a microcontroller on the board so ideally I want to be able to tune it for the highest amplitude.
I know that op-amps can replace inductors. So I think I should be able to adjust (through a digital pot) the resistor in the op-amp circuit that simulates/replaces the inductor.
Would such solution work?
Can I get a very high-Q response by replacing the inductor with a op-amp circuit?
If yes, how?
Many thanks :) :)
« Last Edit: December 21, 2019, 04:15:01 pm by ricko_uk »
Offline awallin
the notch center frequency might help here... kHz, MHz, GHz ??
The following users thanked this post: ricko_uk
Offline dzseki
  • Country: hu
Also if you exactly know what you are looking for consider lock-in amplification instead of high-Q filtering.
HP 1720A scope with HP 1120A probe, EMG 12563 pulse generator, EMG 1257 function generator, EMG 1172B signal generator, MEV TR-1660C bench multimeter
Hi Awalling,
200 KHz is the Frequency.
Thank you
Thank you Dzseki,
I googled for hours to find a lock-in amplifier IC or schematic but couldn't. Do you have any pointers for a simple solution?
As I mentioned in the reply above the carrier freq is 200KHz and I do have the original clock available on the board as sinewave (I can also make it square wave).
Many thanks :)
Online Kleinstein
The OP based filters usually need an OP GBW well higher than frequency times Q value. So a high Q at 200 kHz is not very practical with an active filter. Here an LC filter is probably better. If needed one could tune it with vari-cap or so.
There could be an option to use a kind of synchronous notch. Some AZ OPs use this method internally, so the corresponding literature could help here.
Is a really narrow notch really needed ? If it is only about getting a deep notch one could use 2 in series.
Offline thm_w
  • Non-expert
Are you talking about a bandpass filter or a notch filter?
https://www.ti.com/lit/an/slyt235/slyt235.pdf
Online nctnico
What does the circuit do? Why do you need to filter the 200kHz signal?
Offline T3sl4co1l
    • Seven Transistor Labs
Also, a PLL, which can be analyzed in terms of a bandpass filter.
Seven Transistor Labs, LLC
Thank you T3sl4co1l,
that sounds interesting. How? Where can I find infos on how to do that?
Thanks
