For plain wood easiest and cheapest is to get liquid fabric softener, dilute with water, and use a mop to wipe over the clean floor. Will leave a thin film behind which is static dissipative, which will slowly bleed charge away. Cheap, leaves a nice scent, and you just reapply when you wash the floor. The polymers are more meant for vinyl sheet, which can, when clean, actually hold a charge.
