Late to the party on the zero crossing bump… the use of a slow leg (Si devices) and fast leg (SiC devices) does mean you get quite a big bump when the slow leg switches.
This is effectively a large common mode signal, and it will couple through stray capacitances to ground. If you’re using a big DC bench supply for the DC link you might have a big stray capacitance inside which is subjected to a 400V swing when the slow leg fires.
Sorry I don’t have time to dig in properly, you may already know this, but the switching of the slow Si leg is determined not by zero crossing of the AC line voltage but instead by the zero crossing of the PWM reference signal. These likely have a bit of a phase offset.
On component destruction: I recommend adding some overcurrent and over voltage trips (gate all FETs off and open relay) to your test software. That way an unstable loop will cause a trip rather than a boom. In a past prototype I even deployed analog comparators and logic chips so it would trip even if the software was bolloxed.
In that previous project, I found that you can get quite a good idea of the current control behaviour by shorting the ‘AC line’ terminals and setting the software to generate its own 50Hz reference.
DC link is supplied internally by transformer isolated LLC stage of microinverter. That transformer have some stray capacitance since its winding are interleaved however I've added Y Cap connecting both grounds to shunt HF current noise.
Currently all MOSFETs are Si. There is no spurious turn on from miller and dv/dt product at slow and fast leg.
For protection there are low side comparators for each leg (and they works fast, 300ns from detection to shut off)
For inline current sensing there is a comparator just after the first opamp at inductor shunt. However here I have a large noise from LLC converter at 2x switching frequency (140kHz x2) so I have added more filtering to that and its not as fast. However its shouldn't be a problem since 1mH grid inductor are slowing down the current so it should works that way.
Regarding phase offset, there will be always some but shouldn't be no more than 2x of switching frequency, so max 40 us, not 500-800 us. That is definitely comes from LC filter.
