Author Topic: Opinion about this bga desing. Uncovered vias between pads?  (Read 1564 times)
Offline DavidAlfaTopic starter
« on: November 22, 2023, 09:46:39 pm »
We're having some issues with customer-designed pcb.
Few bgas are failing, either due ball migration (short), not properly soldered (ball sit on the pad but not soldered ), others show nothing strange under x-rays.
They use a weird flux, not even close to Amtech, seems like a semi-liquid rosin flux with terrible obnoxius fumes that will make you choke out.
I decided to take one of the ones tagged as scrap / unrepairable.
Well, I'm not expert but those uncovered vias look like sh** asking for trouble very loudly!
Just to my own curiosity, I reballed it using my $7 chinese bga kit + $22 858D hot air station.
My other tests (fbga 0.3mm ball dram ic, 0.25mm emmc) looked perfect under x-rays.
I'm not telling I'm better than them, just for curiosity.
The mcu itself may be damaged after all (Bad ADC reading in one channel).
Tomorrow we'll see how it look under the rays.
These boards are getting seriously tanned :-DD
« Last Edit: November 22, 2023, 09:49:22 pm by DavidAlfa »
Offline ataradov
    • Personal site
Re: Opinion about this bga desing. Uncovered vias between pads?
« Reply #1 on: November 22, 2023, 11:32:49 pm »
What is even going on here? Untented vias are a non-starter, of course. But why do they have some pads without holes? Are half of the vias plugged and others are not?
Alex
Online PCB.Wiz
« Reply #2 on: November 22, 2023, 11:42:11 pm »
I wondered that, but I think they've just done a break-out footprint, and have used via in pad routing for those pins.
I notice a couple of much smaller holes appear on vias to the left ?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: November 22, 2023, 11:57:13 pm »
Seems like there's two sizes of hole used, and both of them erratically are plating shut at the board face.  Seems like the fab quality is matched only by the layout design quality..!
Seven Transistor Labs, LLC
Online langwadt
« Reply #4 on: November 23, 2023, 12:22:01 am »
what on earth where they thinking?
Offline shakalnokturn
« Reply #5 on: November 23, 2023, 12:25:20 am »
Were they thinking (at all)?
« Reply #6 on: November 23, 2023, 04:37:21 am »
These were my thoughts, and yeah, I also doubt this is a fab problem, but 100% originally designed this way.
Amazingly, only about 2% are failing!  :-DD
« Last Edit: November 23, 2023, 04:40:58 am by DavidAlfa »
Offline SiliconWizard
« Reply #7 on: November 23, 2023, 05:40:23 am »
This layout is quite funky. I suspect they may have defined a number of different vias in the project, and then selected either of them without much care while adding vias, as long as they fitted. It may have not been too obvious in the layout editor itself. They should have had a look at the Gerber though.
« Reply #8 on: November 23, 2023, 07:38:27 am »
After reballing myself, checked the x-rays and surprise!
Two balls were sucked by nearby vias. Rest were perfect.
Not my problem. Engineers are ok with that, not my job, I just gave it a try at my own.
« Last Edit: November 23, 2023, 07:40:15 am by DavidAlfa »
Offline ArdWar
  • Country: sc
« Reply #9 on: November 23, 2023, 08:10:21 am »
Why didn't they use pad in via if they already went such length to get plugged vias? Did I miss something obvious here?
Either failure to recognize a problem or failure to cost optimize, neither feels like a good impression for the designer.
« Reply #10 on: November 23, 2023, 02:48:10 pm »
Yeah, after several years I came to the conclusion I either work for Nike, or my company is sponsored by them, there're too many "Just do it" !
Offline twospoons
« Reply #11 on: November 23, 2023, 09:55:37 pm »
Its probably just a mix of blind and thru vias. But leaving them uncovered was silly.
« Reply #12 on: November 23, 2023, 11:09:09 pm »
Yes, after analyzing the pinout, it's a net class thing.
Power pins (VDD, VSS) have via holes, signal ones (GPIO) doesn't.
