Author Topic: Subtracting a constant voltage from an input voltage  (Read 19493 times)
Offline BurnedResistorTopic starter
  • Country: at
Re: Subtracting a constant voltage from an input voltage
« Reply #25 on: October 26, 2016, 08:38:01 pm »
Helps to attach a file  |O
Offline Ian.M
« Reply #26 on: October 26, 2016, 08:54:49 pm »
Its hitting the -ve rail hard.  Simulate it again with +/- 15V supplies to the LT1881, then use the principle of Superposition on sources V2 and V3 to understand WHY its hitting the -ve rail when operating with a 5V single supply.
Offline dannyf
« Reply #27 on: October 26, 2016, 10:41:49 pm »
A summing amp does what you want.
Offline strawberry
  • Country: lv
« Reply #28 on: October 27, 2016, 12:00:14 am »
Rail-to-rail op amp
zeners are not good for frequencies
Offline Smokey
  • Not An Expert
« Reply #29 on: October 27, 2016, 12:46:29 am »
Lots of good circuits here.  As I read through you guys already ticked off all of the ways I was thinking of.  Fun!
