I like to have a symmetrical audio input infront an ADC that operates with a single supply of 5V.
I choosed the TL072 for that purpose, because it works with audio and I had it laying around.
Here is the schematic:
In theory, I lifted the positive path to a DC of 2,5V, that is produced by the voltage divider R57/R62.
R56, R58, R59, R60 (100k) are the regular resistors for the symmetrical amp.
R61 may not be needed here.
If I operate the thing with 1Vpp sine out of my function gen (positive input 0deg, negative input 180deg shift) I get the waveform below on the output.
If I lift the positive sine to 1V DC up, everything looks fine.
If I switch off one of the both input signals, the output vanishes (I expected half voltage on the output here)
Why is that, where I did a mistake by modyfing this circuit?
Thanks for your advices!
