Author Topic: Showcase Uno based PCB Pre-Heater w. active Temp Monitoring  (Read 204 times)
Offline pcarewTopic starter
I have developed an Arduino Based Pre Heater for PCB Rework that some may be interested in. This project has:
  • Precise temperature control
  • Selectable Temperature Profiles
  • Manual Temperature settings
  • Heater enable/Disable
  • LED Indicator status profiles
  • Rotary menu selection / manual temperature setting
  • TFT Graphing of measured temperatures
  • Serial streaming of Temperature readings for off-heater plotting and/or recording
  • Fuzzy Logic / AI based Temperature control engine
All of this is crammed onto an Arduino Uno R3.
For specific details see: https://github.com/pcarew/PaulsPCBHeater
« Last Edit: July 20, 2024, 06:57:45 am by pcarew »
The following users thanked this post: pardo-bsso
