Author Topic: Substitute for ADCH-80A rf choke  (Read 3195 times)
Offline Dragon88Topic starter
« on: April 26, 2015, 12:48:06 pm »
Quick RF question. I have some spare Mini-Circuits Gali-52+ amps on hand from repairing a piece of equipment. I'd like to make a small general purpose LNA board with them. The reference design I have seen (and the thing I repaired) uses a Mini-Circuits ADCH-80A wideband choke for the bias to the amplifier. Unfortunately, the minimum quantity is 20 on Mini-Circuits website. I was hoping to find a cheaper alternative.
Is it possible to select a substitute fixed inductor and maintain the wideband nature of the circuit? The ADCH-80A is good for 50 MHz to 10 GHz. My application would be fine with 50MHz to 2 GHz. I understand SRF is a factor when selecting a choke for a specific frequency, but I'm not sure how to handle the wideband requirement.
Thanks!
Re: Substitute for ADCH-80A rf choke
« Reply #1 on: April 26, 2015, 08:34:12 pm »
Here's a sample of what I'm finding searching Digikey. An inductor with a SRF of 2.1GHz, but very low impedance at the low frequency of operation:
http://www.digikey.com/product-detail/en/LQW15AN91NG00D/490-6853-1-ND/3846050
Larger inductors of course have lower SRFs, but I need something closer to a uH to have a reasonable impedance at 50MHz. Should I just use both in series? Is that how the "wideband" rf chokes achieve their performance, or is it something more complicated?
« Reply #3 on: April 26, 2015, 09:36:14 pm »
Well that thing certainly looks cool.  8) But based on the theory of how it works, looks like I might be on the right track with multiple series inductors.
