Author Topic: Oscillations! Linear variable PSU  (Read 8218 times)
Offline Datguy123Topic starter
  • Country: sg
« on: May 17, 2020, 03:00:04 am »
Hopefully someone can help me! I've been stuck on this problem for a week.
I'm designing a linear variable PSU which can output 45V@6A. It was put together with whatever I know about electronics (I'm a rookie) and it managed to work until I started load testing with heavier loads (from a 100 ohm load to a 6 ohm load). What happened was that high-frequency oscillations (around 1 to 5Mhz) started appearing as I increased the output voltage and consequently the current. This is a prototype circuit and I have built it on perfboard and have long wires everywhere (between the reservoir capacitors and the output transistors, output transistors and feedback resistors...) presumably causing the oscillation problems. The initial oscillation was periodic and has an amplitude of around hundreds of millivolts to several Vpp which increases and starts merging (the envelopes joins together to form a constant oscillation) with the output current/voltage. The oscillation is not sinusoidal like and looks "chaotic". Furthermore, the oscillation seems to be "polluting" the entire circuit, as upon probing I realized was superimposed to all signals in the circuit, making it hard to locate its origin.
I suspected it was the output transistors causing the oscillation, so I added 1nF capacitors between the collectors of the output pairs and the heatsink (C15 and C16) as well as 4.7 ohm base stopper resistors (R2 and R6). However, the addition of the capacitors caused the oscillations to increase instead. By experimentation, I left 1nF C15 in because it reduces the oscillations (C16 does the contrary). This pushed the voltage before the oscillation starts higher, but in no way removes the oscillation. Grounding the heatsink reduces the "chaotic" behavior of the oscillation.
I started to probe around the circuit and realized that whenever I probe the collector of driver darlington transistors (either one, Q1 and Q13), the oscillations will magically go away. My initial thought was that the capacitance of the oscilloscope probe was bypassing the oscillations to ground, so I did just that by using 12pF for C13 and 1nF with 12pF for C14, which pushed the point where oscillation starts higher. It is weird that if I use 1nF for C13, the output oscillations will increase.
I've tried other things as well, listed below:
1. Smaller bypass capacitors (100pF) for C15 and C16, only reduces the amplitude of the oscillations
2. 4.7k base stopping resistors for Q1 and Q13, but resulted in way bigger and weirder oscillations (in the whereabouts of 5 to 6 Vpp at 11 volts output!). With this, oscillations are found to start from the base of Q1 and Q13 and not from the differential pair circuit.
3. 100pF C19 and C20, but does not remove the oscillation.
I am lost as I am unsure if the problem is because of the circuit design or layout. I am also unsure why adding slightly bigger capacitors would cause bigger oscillations (for C13). I hope my description of what I have done is not too messy and any help would be appreciated! Thank you for your patience because this is a rather long post.
Please note!
1. The LtSpice schematic is ONLY used to visualize the circuit
2. The operational amplifiers in the circuit are in fact LM358 (not OP747). U7,U8 are in a single package, similarily for U5 and U6
3. The circuit works by splitting the voltage drop equally between 2 pairs of transistors (X volts across Q2, Q12 and around X volts across Q3, Q11). Ideally, at 0V output the emitter voltage of Q2 and Q12 is 25V
4. -15V, +12V, and +2.78V rails are powered from the same transformer but from a separate winding.
« Last Edit: May 17, 2020, 03:02:21 am by Datguy123 »
The following users thanked this post: actuallyjaseg
Offline ogden
  • Country: lv
Re: Oscillations! Linear variable PSU
« Reply #1 on: May 17, 2020, 05:10:40 am »
Where's schematics of actual circuit? Sorry, but your "distributed rats nest PSU" is full of feedback antennas, no wonder it oscillates.  I won't even consider working on frequency/stability compensation for such circuit & layout unless error amp, power amp and output transistors are on compact perfboard w/o wires flapping around.
  • Country: sg
« Reply #2 on: May 17, 2020, 05:41:36 am »
My bad, forgot to attach the circuit. Thanks for your advice, I'll try to clean up the layout but do you think there's anything apparent in my circuit that could attribute to the oscillation?
Offline xavier60
« Reply #3 on: May 17, 2020, 06:03:17 am »
When I was rats nesting my project I kept the loop consisting of the pass transistors and bypass capacitors confined to a small area at the heatsink.
https://www.eevblog.com/forum/projects/linear-lab-power-supply/msg2028295/#msg2028295
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline gbaddeley
« Reply #4 on: May 17, 2020, 06:40:17 am »
U5 & U7 are open loop at DC, too much gain!  The driver transistors should have a base stopper 22 - 100 ohms. Get rid of c10. Why are you using the 2 x transistor diff stage? There are easier ways to do level / current shifting.
Glenn
Offline xavier60
« Reply #5 on: May 17, 2020, 07:01:30 am »
The Darlingtons should be driven in the same way that works well in audio amplifiers. A Voltage Amplifier stage consisting of a capacitively loaded trans-conductance amplifier.   The opamp will need to have some proportional gain for loop stability.
https://electronics.stackexchange.com/questions/254375/purpose-of-voltage-amplifier-vas-in-three-stage-amplifier-design
« Last Edit: May 17, 2020, 07:03:09 am by xavier60 »
Offline ogden
  • Country: lv
« Reply #6 on: May 17, 2020, 09:10:05 am »
Sorry, but your circuit is rats-nest as well :) Main beauty of best hobby engineering projects is simplicity. Why two stages in series? My advice - divide your project in logical steps, work on single suply until it is running, only then add/connect 2nd.
Offline xavier60
« Reply #7 on: May 17, 2020, 10:09:55 am »
This is the most simple way to level shift drive up to the high-side.
« Last Edit: May 17, 2020, 12:04:53 pm by xavier60 »
  • Country: sg
« Reply #8 on: May 17, 2020, 11:19:36 am »
Hi, would it be a big problem for U5 and U7 to be open-loop at DC? If so what changes do you think I can make? I used the diff pair because a single common emitter would introduce a 180-degree phase shift and I don't think the NFB would work. In my previous design, I used dual common-emitter stages together to shift the phase back to 0, but I think a diff pair is more "refined". C10 was added to remove a 300++khz oscillation when the power supply is unloaded; not sure if this is normal tho. Would try out a lower value for the darlingtons.
  • Country: sg
« Reply #9 on: May 17, 2020, 11:34:06 am »
Hi, so are you saying the Darlington should be configured to have both voltage and current gain? I have no formal education in EEE so I am not sure how much gain the op-amp should have. My plan was to use the diff pair as the VAS and use the temperature stability of the op-amp to correct the errors in gain using NFB. The darlington was used to provide large current gain at high output voltages when the current in the left side (Q9 and Q17) is low.
Offline xavier60
« Reply #10 on: May 17, 2020, 11:52:09 am »
Just like with an audio amplifier, the Darlington's current gain buffers the VAS.
 Having a single inverting VAS transistor can be corrected by swapping the opamp's inputs so long as its local feedback still goes to its inverting input. A resistor will be needed in series with the feedback capacitor.
 If you drive the VAS transistor's Base directly with the opamp, Vas compensation will need to be done with a capacitor from Collector to ground.
Look at some typical AB audio amplifier circuits for ideas.
  • Country: sg
« Reply #11 on: May 17, 2020, 12:10:40 pm »
Hi, I thought of using two stages because of the SOA and power derating of the output transistors. If I series them, I would get more power from the output transistors at lower output voltages. I would try separating the two series parts, but the circuit works at with lighter loads so I'm not sure if I would need to take such drastic measure.
Offline gbaddeley
« Reply #12 on: May 17, 2020, 12:30:51 pm »
1 stage is enough. Parallel up as many power transistors as you need (run them at <50% Pmax) use a big enough heatsink (Tcase <80deg.C).
Glenn
Offline xavier60
« Reply #13 on: May 17, 2020, 12:51:00 pm »
For the TIP35, max dissipation drops from about 120W at 30V to about 40W at 60V. That's a drop from 4A to 0.6A.
Offline ogden
  • Country: lv
« Reply #14 on: May 17, 2020, 12:54:16 pm »
Don't. Why don't you look how it is done in other "DIY supplies"? This forum alone is full of powerful enough linear supply circuits that uses parallel output transistors instead of weird two supplies in series arrangement.
Offline xavier60
« Reply #15 on: May 17, 2020, 01:11:56 pm »
If it will always be outputting 45V at up to 6A, one paralleled set of transistors will do, assuming an input of about 60V.
If the output needs to be set to much lower voltages, then it will be difficult to deal with unless the input voltage can be reduced also.
Offline ogden
  • Country: lv
« Reply #16 on: May 17, 2020, 01:18:24 pm »
Good point. Introduce either mains transformer with multiple output taps (oldskool approach) or switching preregulator + LC  filter.
  • Country: sg
« Reply #17 on: May 18, 2020, 07:18:35 am »
Unfortunately, the supply I'm planning to build have the full output range of 0-45V. As u mentioned earlier, parallelling transistors would definitely not be a practical solution here.
The aim of building this power supply is to utilize the parts I have available to me. The transformer I'm using comes from a power amplifier and does not have lower voltage taps on the main secondary winding. I wouldn't want to rewind the transformer because my lab doesn't have the capabilities to do so.
I also wouldn't want to introduce a switching regulator as I want the suppy to be as linear as possible and it might introduce more complexity to the overall circuit.
I know the design I created completely negates efficiency, simplicity, and practicality, but it wouldn't hurt to try out a new method. I envision using this as a learning point, and since I have came a long way from a blank piece of paper to a partially working circuit, I would like to cling on to any hope that the circuit could be mended to work. This might be foolish of me to you more senior engineers but I don't want to give up this circuit just yet. I hope you can understand my point of view and aid me in completing this project.
Offline xavier60
« Reply #18 on: May 18, 2020, 10:16:23 am »
You are rectifying the secondary into split rails? What are the voltages.
Some amplifier transformers have  lower voltage taps in the secondary so that the rail voltages can be reduced when the speaker impedance switch is set to low.
  • Country: sg
« Reply #19 on: May 18, 2020, 03:53:05 pm »
The amplifier is a conventional class AB type. Wouldn't want to tear apart a fancier class G that has split rails. Anyways, the transformer has 4 secondaries, 2 secondaries to supply the low powered electronics, and 2 center-tapped secondaries for the power amplifiers. They are of similar voltage (+/- 54Vpk unloaded wrt to the center tap), and I am going to parallel them to increase the output current.
Offline ogden
  • Country: lv
« Reply #20 on: May 18, 2020, 05:23:57 pm »
Ok. That is constraint indeed, but good one.
Power amplifiers usually have two secondaries and possibly some auxiliary winding. In case power secondaries are two separate windings - you have option of "middle tap". Connect secondaries in parallel to get lower voltage & double current, connect in series to get higher voltage lower nominal current. Simplest way to switch between two - relay.
  • Country: sg
« Reply #21 on: May 22, 2020, 09:11:15 am »
The power secondary windings are center-tapped. 2 identical power secondary windings of 3 output taps 57Vpk-0-57Vpk. No way to decrease the voltage further.
So you're saying that local feedback is needed for a single transistor VAS, such as a miller capacitor? Is it to reduce the gain at high frequencies and ensure sufficient phase margin? I am unfamiliar with the topic of poles and zeros and have no idea what sort of feedback/compensation is needed to deter any instability.
So in your suggested configuration, my circuit would have a single transistor common-emitter stage driving a Darlington driver stage but does this have an advantage over using a differential pair as the VAS instead apart from part count?
If you drive the VAS transistor's Base directly with the opamp, Vas compensation will need to be done with a capacitor from collector to ground.
Sorry, but what does VAS compensation do? And why only if it's driven directly from the op-amp?
Anyways with my current design, are there other areas I have overlooked? I am planning to add current limiting as well, by placing a shunt transistor between the non-inverting terminal of the U7 and ground but would that be a problem because of the slew rate of the op-amp?
Offline xavier60
« Reply #22 on: May 22, 2020, 09:53:27 am »
There is little difference between a typical AB audio amplifier and a power supply with an Emitter follower output stage.
I don't properly understand Poles and Zeros.
With the audio amplifier, from the inputs to the output of the VAS, it's a trans-conductance stage. Input voltage difference signal causes an output current signal. So long as the VAS output is lightly loaded, it results in very high voltage gain.
 To make the loop stable with feedback applied, the response is made to fall with increasing frequency. This is done by directly loading the output of the VAS with a capacitor or putting a Miller feedback capacitor between C-B of the VAS transistor.
The idea is to have the gain drop too low for oscillation to occur before the phase shift of the whole loop exceeds 90°.
I see no advantage in having a differential VAS stage unless it's for having a current mirror on the high-side.
The single VAS transistor can have its Base directly voltage driven by the opamp and have an Emitter resistor which will cause it to be a simple voltage to current converter. The compensation capacitor would go between C-E.
Or the Base could be current driven via a resistor, no Emitter resistor. The capacitor goes between C-B.
The opamp makes things a bit messy, it will need local feedback to reduce its gain to something low but must not have any significant roll off.
I have likely missed something.
Buy now, the topology I suggested in Reply #7  should be starting to look like a good idea.
  • Country: sg
« Reply #23 on: May 25, 2020, 06:52:20 am »
Thanks for the advice. Seems like I will redesign the power supply with regards to reply #7, but have 2 identical series stages instead of 1. I have a few questions, in that schematic, does Q2 aim to provide voltage gain and current buffering at the same time? Without an emitter resistor, wouldn't the voltage gain of that stage be huge? Also, how are the values of C9, C3 and C4 determined? And are base stoppers not needed for the output transistors? Thanks again, and sorry for all the late replies.
I would be enlisting soon so this project will be put to a temporary halt.
Offline xavier60
« Reply #24 on: May 25, 2020, 08:41:35 am »
Needless to say, develop it as a single stage first. Deriving the dynamic reference for the 1st stage could get challenging.
Q2 and the TIP35C's form a Sziklai pair, it could have also been a PNP Darlington.
https://www.electronics-tutorials.ws/transistor/darlington-transistor.html
Power supply design topologies can be divided into 2 groups, voltage sourcing and current sourcing. The one I'm suggesting is the current sourcing type.
The Sziklai pair has a high current gain, anywhere from 5000 to 15,000, maybe wider,  depending on the spec of the particular transistors used.
Q2's Base sees voltage drive via 1K resistance. Overall, a voltage change applied to the Base of Q1 causes a current change at the PSU's output. And with good linearity, surprisingly.
C3 and R5 are for CV loop's compensation. The default values should result in a stable loop for a wide range of output transistor specs.
The CV compensation can be the optimized by trial while doing a repetitive load transient test.
C4 is for CC loop compensation. Because the PSU's outputs stage has a constant current sourcing characteristic, the loop response can be  made slow.
The value of C4 isn't critical but might need to be scaled to different CS resistor values. I haven't given much thought to if low-side sensing can be used for your project.
 Follow the layout suggestion I made in reply #3.
Depending on layout, Base stoppers should not be needed. I have been using the design in a bench supply for a year with no sign of local oscillation. The only trouble I had was a short loss of regulation if an arc was caused while connecting a load. It was a layout problem causing high levels of hash to reach the inputs of the CV opamp.
https://www.eevblog.com/forum/projects/linear-lab-power-supply/msg2388873/#msg2388873
« Last Edit: May 25, 2020, 09:37:14 am by xavier60 »
