Author Topic: Oscillations in BJT (active load project)  (Read 8157 times)
Offline tfmTopic starter
« on: May 28, 2018, 02:35:36 am »
Hello,
I am set on building a programmable active DC load for the lab at our University. User can choose constant current, constant voltage or constant power. It needs to withstand up to 200V and dissipate 1kW.
After some research, I decided to try a first version of it paralleling a couple of power darlington BJTs. Also tried the "active ballasting" found on tAOE3 (the art of electronics), pg 113, Fig 2.82:
(I hope I am not infringing any terms here by posting the picture. Please let me know otherwise.)
So the circuit below is to be used when constant current is selected, here Vset sets 1A. In the final version, Vset will come from a DAC. Here are just the bare bones of the passing elements + active ballasting:
BJTs Xmjh11022 are actually MJH11022. The model came from OnSemi:
http://www.onsemi.com/PowerSolutions/supportDoc.do?type=models&category=809
Here is the circuit response:
I am attaching the Ltspice sim file + lib.
It gets worse if current sink I1 sets a higher current.
It gets better if load R5 is higher.
My guess is that this behavior suggests parasitic oscillations coming from passing elements Q2 and Q4 Ceb, and its Miller effect. Also seems weird that because the way Q4 and Q3 are connected, the capacitance Ceb * (hfe +1), from Q4 should equal Ccb from Q3, since they are shorted. That sounds odd...
But I can't figure out precisely what is the cause of the oscillation, specially since there is no real world parasitics (traces/leads inductances, etc) in the simulation.
A few notes I think are worth mentioning:
1) I have the same results if just one side of the circuit is used (ie, if I delete everything to the left of I1)
2) It doesn't matter if I use an op amp in a closed loop to set the current as I did, or if I just replace Vin for a simple DC supply. The oscillation is the same.
3) I know that the full specs (160VDC, 1kW) required will release the magic smoke of the passing elements in a moment. These requirements do not comply with its SOA. If I go with the MJH11022, I will probably have to set 4 of them in series, then 4 of those sets again in parallel to go safe. I am just sticking to a simple simulation now.
4) I know I can also use MOSFETs, but we are short on power FETs and we have are many power BJTs available, so we are sticking with them. Ironic is that MOSFETs are known to have stability issues, not BJTs  :-//
5) I couldn't tame the oscillations with resistors at Q1/Q3 base, or adding caps at any place i could think of.
6) I did have a clean current, no oscillations, by adding small 33 ohms resistors at Q1 and Q3 emitters (between emitter and I1), but that failed if raise the current, say from 1 to 5 amps.
7) If the darlington Q4 and Q2 are replaced for a MJ15003 (single, non darlington bjt) it won't help either, oscillations start just at 1.1 amp, for the same 1 ohm R5 load.
8 ) I don't want to increase the emitter degeneration resistors (of the main passing elements), since the whole purpose of the auxiliary Q1 and Q3 transistors + current sink I1 is to ensure equal current sharing and avoid thermal runaway using lower ballasting resistors. I want to dissipate as much power as possible using the passing elements, not passive components.
I could use some help to really understand what is happening to this circuit and how to fix it!
Offline David Hess
  • DavidH
Re: Oscillations in BJT (active load project)
« Reply #1 on: May 28, 2018, 12:15:09 pm »
This does not answer your question but that is an interesting circuit idea.  Unfortunately it has the same problem; variation in the Vbe between Q4 through Q6 creates the same imbalance that they were trying to correct.  Those transistors need to be matched which practically means operational amplifiers should be used instead as the most economical way to get matched transistors.  Driving each output transistors with its own operational amplifier with feedback from its emitter resistor is usually how it is done.
I cannot tell what the frequency of oscillation is or the units.  Knowing them would help.
Q4-Q6 operate with a Vce down to 0.6 volts which should be fine for the BC337 but some transistors will have a problem with this.
Does the simulation oscillate with Q4-Q6 removed?  They may have too much transconductance in which case adding emitter resistors will help.
The following users thanked this post: tfm
Offline Jay_Diddy_B
« Reply #2 on: May 28, 2018, 12:33:22 pm »
Hello,
Snip ...
You need tp look at the FBSOA for these transistors:
You will be limited to about 40W dissipation by the second breakdown limits.
Regards,
Jay_Diddy_B
« Last Edit: May 28, 2018, 12:49:31 pm by Jay_Diddy_B »
Offline capt bullshot
« Reply #3 on: May 28, 2018, 01:40:06 pm »
 The oscillation is a result of U1 (the error amp, providing a large gain) beeing faster than your boost stage (your output transistors and current sharing circuit).
It's a common and simple rule of thumb that the error amplifier (here U1) must be slower than the loop - you may want to look up circuits providing either current or voltage boost to an OpAmp in the literature - I believe both The Art of Electronics and Jim Willams' App notes have some examples and notes.
Modifying the circuit as shown brings you stability.
And yes, you'd need to make R2/R4 large enough so that Q1 / Q3 Base to Emitter voltage variations have small enough influence to the current sharing. You'd also want to keep Q1 and Q3 at the same temperature by mounting them in near proximity.
« Last Edit: May 28, 2018, 01:43:55 pm by capt bullshot »
Offline David Hess
  • DavidH
« Reply #4 on: May 28, 2018, 02:02:46 pm »
I assumed that "2) It doesn't matter if I use an op amp in a closed loop to set the current as I did, or if I just replace Vin for a simple DC supply. The oscillation is the same." meant that he measured the output at the top of R5 so I ignored U1 but you unintentionally brought up another point here.
U1 is an OP37 which is an OP27 decompensated for a closed loop gain of 5 or greater.  Adding a feedback capacitor between the output and inverting input will just make things worse and likely create a local oscillation around the OP37 no matter what the simulation says.  I have run into this before with the OP37 before I knew any better and some specific values of feedback capacitor sort of worked but the control loop and even the OP37 in isolation was never robustly stable like it should be.  Use a unity gain stable operational amplifier.
An OP27 would be more suitable but still too fast so it will require external compensation.
Note that an OP37 can be externally compensated for unity gain stability if the circuit configuration provides for a minimum *noise gain* of 5 but this is seldom a good idea; increasing the noise gain to provide stability at low closed loop gains defeats the purpose of using a low noise operational amplifier.
http://www.analog.com/en/analog-dialogue/articles/techniques-to-avoid-instability-capacitive-loading.html
http://www.analog.com/en/analog-dialogue/articles/ask-the-applications-engineer-25.html
« Reply #5 on: May 28, 2018, 02:19:26 pm »
@David Hess:
You're right with your concerns about the OP37. I wouldn't use that Amp here also.
As I tend to put a generic OpAmp into such simulations, I didn't look at that detail. The simulation is to see if it can work in general, but for the real circuit there's still left optimization to do on the real prototype, this is my approach to simulation. This includes component choice.
@tfm
I forgot to mention, this brings stability together with the 33R resistors in Q1 and Q3's emitters. Having no emitter resistors, the circuit still oscillates, as it does with the control loop removed. I messed up the schematic a bit while searching for the oscillations cause, so I forgot about these.
So we've got two sources of oscillation here:
The output stage itself, which needs the 33R resistors in Q1 and Q3's emitters
and the error amplifier, which needs compensation as shown, and as David mentioned, you should better use a unity gain stable amplifier.
P.S.
Don't connect a real OpAmp as shown in your original circuit (without series resistors to it's inputs). Especially these OP27 style amplifiers have protection diodes across their inputs, which will start conducting at more than 0.6V voltage difference between + and - input. With low impedance sources as in your circuit, the amplifier will be destroyed at first turn on due to the high current through these diodes. This is why I added R11. Anyway, R11 is also required for C1 to have an noticable effect.
I also increased R7 to 100R, just because this is the "rule of thumb in this context" value for an emitter followers base resistor - there's been a nice RAQ about this recently:
http://www.analog.com/media/en/analog-dialogue/raqs/raq-issue-151.pdf
« Last Edit: May 28, 2018, 02:28:41 pm by capt bullshot »
Offline SiliconWizard
« Reply #6 on: May 28, 2018, 02:28:16 pm »
Try replacing the opamp with an AD8510 for instance. It will behave.
Offline schmitt trigger
  • Country: mx
« Reply #7 on: May 28, 2018, 03:52:36 pm »
"Safety devices hinder evolution"
Could not agree more. It prevents the natural application of Darwin's law.
The following users thanked this post: capt bullshot
« Reply #8 on: May 28, 2018, 05:42:51 pm »
You are right, I gave it a quick look, that is why I mentioned:
But now I see that I've overlooked the real numbers. For that part, it will probably take 6 sets of four in series. Thanks for bringing it up!
« Reply #9 on: May 28, 2018, 06:17:00 pm »
@David Hess:
I see, that is a nice approach. But I had issues with that in the past, precisely for what is happening now again: an ideal op amp will hide potential failures that otherwise may be caught at the simulation stage.
@tfm
I understand. Great. Could you elaborate (or point a direction) about the output stage instability cause - that requires the 33R resistors?
I took a look at the HF response of BJT and HF impedance gyration, trying to understand better the oscillations on such a simple circuit - particularly Dennis Feucht articles:
http://audioworkshop.org/downloads/AMPLIFIERS_OSCILLATION_BJT_CIRCUITS.pdf
https://www.edn.com/Home/PrintView?contentItemId=4401129
Acording to these articles, being main Q2/Q4 emitter followers, a small cap across base resistors R1/R3 should make it better, but they actually make things worse (without the 33R resistors).
What is the cause of the oscillations (just considering the output stage), and why the emitter degeneration resistors fix them?
P.S.
Great tip! Thanks.
@David Hess: thank you for your replies. Very instructive.
« Reply #10 on: May 28, 2018, 06:48:52 pm »
If I remove the op amp, then it does not oscillate with Q4 and Q6 removed.
However, with Q4/Q6 present (and no op amp, just direct drive) it oscillates at ~7MHz:
What was bugging me is that I've seen in more than 2 references (one of them tAOE3) that this current sharing trick was extensively used by some old HP/Agilent power supplies. It is elegant, I'd like to make it work in the real world.
« Last Edit: May 28, 2018, 07:06:50 pm by tfm »
« Reply #11 on: May 28, 2018, 06:57:52 pm »
OK, I can't give you all the theory, I'm rather a guy of practice. I'm used to solve complex differential equations in real time and watching the result on a a visualization device together with a mixture of experience, rules of thumb and a portion of gut sense. (vulgo a prototype circuit, a scope or other suitable instruments, and a good mixture of educated guesses, gut sense and some experimentation,  combined with a bit of simulation and rough calculation).
So here's my approach:
From theory I know (yes, I've got the complete professional EE education with a Diploma, but I forgot most of the details of theory), circuits tend to oscillate if there's too much gain or too less phase margin. Your output stage is expected to work with simple BJTs from my experience (and the AoE circuits usually are expected to work, since they result from practice), but using a darlington tends to mess up stuff. So there's too much gain here, and darlingtons tend to be slower, so your phase margin is also gone. You'd need to reduce the gain, that's what the emitter resistor does. Some oscillator circuits don't look much different from that output stage, just some reactive components (L/C) added. L/C parasitics are everywhere in the real world.
Any emitter follower has a tendency to oscillate, that is why you add a base resistor. Bypassing the base resistor with an capacitor make the resistor pointless for higher frequencies and the oscillation starts over again (that's what you've seen with caps across R1/R3).
If you carefully watch your simulation with the emitter resistors set to a low value (say 1R), you see the current in the 0.05R resistors is anti-phase. So this thing acts somehow as a differential stage going into oscillation. You've got oscillation, then you'd reduce gain (add emitter resistors, these reduce the differential gain) or compensate (add collector to base capacitors, but ensure there's high enough impedance in the base driving circuit, add a base resistor if necessary).
Opening the loop (as you did by replacing U1's output by a voltage source) is a good way to see where oscillations start from. A more advanced way would be to use a step (or square wave) source to see the step response of your circuit, that reveals otherwise hidden tendencies to oscillate.
« Reply #12 on: May 28, 2018, 07:02:45 pm »
Another question about this circuit. Horowitz/Hill say that this circuit works particularly well with MOSFET (also on Figure 3.117, pg. 214) and with power Darlington BJTs, because of their negligible base/gate current.
But what is the caveat of using regular non Darlington BJTs ??
« Reply #13 on: May 28, 2018, 07:13:30 pm »
Don't have the AoE at hand ATM, so I cannot look it up now, I remember the circuit, but not the caveat you mention.
I can imagine, the issue with non-darlingtons is the larger base current required by them (as a rule of thumb, the darlington may have an hfe of 200...2000, a power BJT rather in the ballpark of 10..100), so for a 10A output you'd have to supply maybe a total 0.2A base current, the current sharing steering transistors may want the same or double amount of collector current to operate properly, this results in a good amount of power dissipation in the steering transistors and a lot of output current the error amp has to provide, you won't get away with these small ones.
Offline David Hess
  • DavidH
« Reply #14 on: May 28, 2018, 09:04:45 pm »
That is about right for a Darlington transistor oscillation.  The control loop for an operational amplifier in this situation would usually oscillate much slower.
It is a great idea as I mentioned but I think the reason HP was able to get away with it was by using matched transistors or possibly a transistor array.  You can certainly do that but transistor arrays are more expensive and less available and separate matched transistors will not track as well with temperature; see my answer below.  It may seem wasteful to use a 20 transistor integrated operational amplifier for each power transistor where a transistor array would be adequate for several but the former is a lot more economical than the later.
The necessary drive current is so much higher that it degrades the thermal tracking of Q4 through Q6.  This might not matter if Q4 through Q6 are part of an integrated transistor array or hybrid which is likely what HP used.
Offline jbb
« Reply #15 on: May 29, 2018, 12:40:40 am »
At risk of being a killjoy, you have a 200V rating. Why not just use boring single BJTs with huge emitter resistors? Surely you don’t need a very low compliance voltage? (problem: emitter resistors must e low inductance.)
Maybe a realistic solution is just to deploy 1 opamp per power transistor. It’s crude but you can divide and conquer.
I’m also curious about how you intend to manage the series connection. Were you thinking about a cascode connection?
Oh yes. With 2kW dissipation you’ll find that the heat sink itself has quite different temperatures along its length (with respect to airflow). This might make it harder to do the current sharing.
« Reply #16 on: May 29, 2018, 03:25:45 am »
I am afraid I am slow on this one. The base currents of the power BJTs have to be significantly higher compared to the darlington/FET counterparts. But that base current is summed at the power BJTs emitters and will add a small heating effect on the same power BJTs - small compared to the much higher current through them.
Why do you say that "the current sharing steering transistors may want the same or double amount of collector current to operate properly"?
If we consider the Figure 2.82 from tAoE, the sum of the Ie currents through the auxiliary BJTs is obviously 30mA, so if one power BJT has its Ic raised (because of thermal effects) compared to the others, then the voltage drop at its emitter resistor (50mohms) gets higher. Therefore auxiliary BJTs base voltage gets higher, then they get a bigger share of the 30mA and the drop on its 220R collector resistor gets higher (and their Vce lower). Since this 220R resistor is also the base resistor for the power BJT, its Vbe gets lower and so does its Ic current.
If the above is right, then all the auxiliary BJTs do is compensate the thermal effect on any Ic (from power BJTs) differentially, compared to the others, dropping the voltage at the base of the power BJT that is ramping up its Ic/Ie current.
The higher base current from the standard power BJT (non darlington) could make it more difficult for the auxiliary BJTs to regulate the base voltage of the power BJTs, but that isn't the case again, since the higher Ib would also set a somewhat higher drop at the 220R base resistor.
I am sure I am missing the critical point here... would you care to show me?
« Reply #17 on: May 29, 2018, 03:40:53 am »
I understand your point. And agree. But we have to do a sanity check. If that holds, and HP did use transistor arrays or matched ones, well then they could simply have used matched power BJTs, mount them together (which they did anyway) and use smaller passive ballasting resistors.
Are matched power BJTs more difficult to get than small signal BJTs? I don't know.
BTW, did they actually measure the auxiliary BJTs in case they didn't use the arrays? I don't think so, even in not-so-large production quantities. And (if) how come they did use the arrays, being more expensive? Those have always been more expensive, right?
« Reply #18 on: May 29, 2018, 05:04:01 am »
Hi, jbb! Don't mind, your suggestion will never be a killjoy!  :-+
There is no hard reason I won't go with a single BJT, really. But since there is no critical time constraint for doing it, I'd like to take a look at the options. And even if, in the end, I settle on the ol' good single BJTs, this whole exercise of looking into these details is fun to me!!
Now, one thing I'd like to avoid is huge emitter resistors. It is kind of just ugly to me, because all that power (BTW, 1kW, not 2kW) will require a massive heatsink + convection. So I should put some effort to dissipate all the power on the part of the circuit that is meant to take it! Not on the resistors. Might be just silly...
I am pretty sure the 1 opamp per BJT will work, and it is indeed realistic. There is no reason it shouldn't be done like that, from my perspective, really. I am just trying to make this suggestion from tAoE work too. Better? I think so, if it doesn't need matched aux BJTs. I guess that is yet to be seen, despite David Hess solid points - please see my next post. Simpler? I guess it will be, after it is been done.
Well, I am considering a cascode or just spreading the Vbe using plain resistors. I haven't tried on the bench with such a high 200V, but it should work:
You know, if we go berserk, and have 20 of those in series, we'll still be wire-bound limited:
With the advantage that it is in series, so the same current is guaranteed through everyone.
Yes, but eventually, if the active current sharing approach works, it should suffice to tune the different legs until thermal equilibrium is reached.
« Reply #19 on: May 29, 2018, 05:14:09 am »
You point at the critical point: The higher base current. In your idea and if every transistor and resistor was born equal, only a small collector current might be necessary for the steering transistors to regulate the current sharing. In practice, it isn't. The power BJT would need quite a high base current, that is set for the worst case lowest power transistors hfe plus headroom. For a quick and dirty calculation, this might be the ten- to twentyfold current than with a darlington. For proper current sharing, the steering transistors would have to take away current from the base for the worst case highest power BJT hfe plus headroom, which may be triple the worst case lowest hfe. From this, a worst case steering transistor collector current of double the maximum required power BJT base current results. This in turn results in quite high power dissipation for the steering transistors and all the related stuff like thermal tracking.
You can get better figures if you select the transistors for hfe, but that's usually a rather expensive process, so the preferred way would be to design your circuit for large tolerances and take measures to keep critical things like power dissipation in the steering transistors low. Then you end up with darlingtons or MOSFETs. By making the power darlingtons emitter resistors larger, you'd reduce the requirements on Vbe and hfe matching of the transistors. So your circuit design will always be a compromise between cost (for selected components), precision (how perfect is the current sharing), and power dissipation (trade larger emitter resistors for cost reduction).
I don't have any problem to figure HP and others could do the power supply circuitry without any matched components by taking the right compromise, but I'm not aware of a specific model or circuit. If someone has an example, I'd like to see it. Service manuals of that age often provide you with all schematics and detailed circuit descriptions, one can learn a lot from that.
« Reply #20 on: May 29, 2018, 05:20:37 am »
Doing so is kind of silly indeed. Power resistors can dissipate way more power than silicon devices for a given size, and dissipating power in a suitable resistor would be the preferred way for most designs.
But I do understand your considerations, if you set yourself a goal to achieve, the way to get there can be way more entertaining and educative than just going for the standard way.
BTW - if you just want to dissipate power in a resistor, you'd put it into the transistors collector, not the emitter. Makes things easier to design, since the parasitics of the resistor have less influence on the transistor. You'd still need an emitter resistor to operate the transistor as a current sink, but you'd design that resistor the usual way and for way much lower power dissipation than the collector resistor.
« Reply #21 on: May 29, 2018, 05:46:00 am »
You know, that need for matched aux transistors is really bugging me. David has a point, but...
On pg 113, tAoE mentions this approach, then again on pg 213 for FETs, and then they say at a footnote that "found this cute circuit trick used in some HP (...) E3610-series linear power supplies. It’s much simpler than using individual op-amps to bias each transistor, as some MOSFET manufacturers suggest".
Matched stuff is not a cute trick, and is not much simpler than op amps, since once you replace them, you might be in trouble.
Here is a thread where Hill advises someone about this approach, to be used in a real circuit:
https://groups.google.com/forum/#!topic/sci.electronics.design/TfOGqGhjTT8
And no one mentioned the need for matched aux transistors.
Here is the schematics for the e3610a:
https://sites.fas.harvard.edu/~phys191r/Bench_Notes/A1/agilent_e3610a.pdf
On pg 15 you can see the parts list. Q4,5 are the aux BJTs that diferentially regulate the power FETs: plain 2x 2n2222a. And the current sink is just a 100k trimpot connected to -12V. (BTW, Q4 and Q5 are drawn incorrectly: emitter and collector are inverted!)
« Reply #22 on: May 29, 2018, 05:56:21 am »
Oh, man. All this time I've been thinking about Vce at aux BJTs... and about the power BJT Vb. Oh man.  :palm:
Thanks.
Please check my previous post.
« Reply #23 on: May 29, 2018, 06:01:59 am »
Well, I am not so sure. If you consider the area or volume of, say, a 10W cement or woundwire resistor vs a 250W TO-247. Not to mention the clumsiness of a heatsink on the former.
But I get your point too. Aesthetic is not a good reason to avoid a higher rated power resistor that could potentially simplify a lot.
« Reply #24 on: May 29, 2018, 06:11:09 am »
Thanks. If you look up all the component values for the different models, you'll find the current sharing is used only for the 60V/120V model. And here, the source resistors are quite large and have a high voltage drop, that easily compensates for component tolerances. The current sink can be tiny here, because the MOSFETs have zero static gate current. A resistor of large value across a relative high voltage can act as a poor current source, that's a common technique for differential amplifiers. Search for "long tailed pair" if you're interested.
(from the google groups thread):
> I have seen BJTs connected this way before to get lower saturation
> voltage, but there doesn't seem to be any advantage to doing it here.
> Or am I missing something?
 It's called inverted mode.  Most transistors have severely
 reduced beta in this mode, but this circuit doesn't really
 need a high beta.
That's their replacement for your 33R emitter resistors to cancel the oscillations. Quite neat, learned something new.
Edit: that's wrong, after finishing reading that thread, it's just a wrong diagram. Transistors are connected as usual.
But the whole power stage appears to be designed with tenfold headroom for everything ... Look at the large voltage drop across the output transistors, this leaves headroom for very low line voltages at the expense of high power dissipation. I've seen this in other gear too.
« Last Edit: May 29, 2018, 06:22:49 am by capt bullshot »
