Ian.M
After you've got some test results, (and put together a documentation package in PDF format), as successful collaborative EEVblog forum projects of general interest aren't that common, it would be nice to send one to Dave for Mailbag.
Absolutely. I need to solve a few small issues, maybe spin a Rev2 with additional trimmers and package it nicely so that it doesn't seem crap
I also would like to try to fit the 4 batteries (AAA) within the PCB area: should be possible but not with the battery holders available on e-bay because they are too big. I would need something as small as metal clips maybe directly soldered on the PCB... Ideas?
The size is dictated by some boxes I currently have available. Maybe I can redesign using a larger box but I like the form factor and portability it has nowadays.
By the way, for the batteroo fans, the output voltage starts decreasing when the battery voltage goes below ~3.6V. The LED turns red at ~3.8V. This means 0.95V per cell and a usage of I think more than 90% of the capacity.
TechieTX
I'm still learning the Microchip parts, but with OTHER microcontroller oscillator circuits you want the variable cap on the input of the buffer, not the output.
I didn't have the issue with the clock not starting up anymore and that's basically why I wend forward with the PCB. Adding trimming to fine tune the frequency is an attractive feature but this project is oriented at calibrating analog scopes with relatively low bandwidth (the output can max 1MHz) so I don't know if we have real need for fine tuning the frequency.
and you'll need to add your KiCad cache.lib library for that project to the github, Marco. Opening your schematic with a vanilla KiCad install gets the screenshot below.
Interestingly enough I had the very same issue
I think it was due to moving the project from a MacOS based PC to my normal Linux based (the laptop was broken at the time when I started). I removed the offending libraries from the project and now should show up fine. Let me know if there's still issues and I'll try to fix them.
