EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Help ID-ing header for SOP breakout board.
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Help ID-ing header for SOP breakout board. (Read 807 times)
romhunter
Regular Contributor
Country:
on:
October 03, 2020, 07:18:41 pm »
Does anyone know what type of connector that was used in this board?
This kind of breakout board is very convenient, I can just basically replace the DIP version with SOP if the need comes up.
Some more description: The pins at the beginning and the end of the connector are normal straight through hole one, and the rest are smd.
Datasheet:
http://www.marutsu.co.jp/contents/shop/marutsu/datasheet/14P-SOD-065-300.pdf
Any help is appreciate. Thank you.
Logged
Benta
Super Contributor
Country:
Re: Help ID-ing header for SOP breakout board.
Reply #1 on:
October 03, 2020, 08:44:38 pm »
Easy:
www.precidip.com
Logged
romhunter
romhunter
Regular Contributor
Country:
Reply #2 on:
October 03, 2020, 11:15:07 pm »
Thank you. This one is single row, 2.54mm however, so I think it is custom designed. Too bad.
It would be nice to have some mass produced variant.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
