Hello Everyone,
I recently designed a non-PFC based flyback SMPS with AL1665 for a power of 150W. The schematic from the application note :
https://www.diodes.com/assets/Evaluation-Boards/AL1665-AL5822EV1-Flyback-User-Guide.pdf is followed.
I have designed it for the universal AC voltage range from 90V rms to 300V rms. Output voltage is desired at 24V.
From the design sheet of the AL1665, the minimum operating frequency was to be 66KHz.
The issues that I am facing are
1) The switching frequency is observed to be at around 16KHz instead of 66KHz
2) Output Voltage is not regulated at 24V at no load. Instead the output voltage just keeps increasing till I turn OFF the input(see attachment - Pink is the rectified HV input and blue is the unregulated output)
3) When the output is loaded with just 50mA, the observation that is made in #2 is more faster
I have checked the FB pin, CS pin, NTC pin and the ADIM pin and all these have spike noises during switching which even inspite of the bypass capacitors are not suppressed(see attachment - Pink is the rectified HV input and blue is the VCC and yellow is the FB voltage)
I had made a design for the same power with other controller UC2843 and there I had did not face this kind of issue of unregulated output.
Kindly let me know what am I missing with this design.
