Author Topic: overkill pikcup combination  (Read 745 times)
Offline ELS122Topic starter
« on: October 21, 2019, 01:14:26 pm »
I found out that whit 3 pickups (5 single coils in this case) you can have an abundance of combinations, somewhere around 1000 I guess
so I built this circuit whit as many switches and combinations as I could stand...
so here it is you can use it if you're crazy!
https://easyeda.com/evalc2636/all-config-pickups
Offline SiliconWizard
Re: overkill pikcup combination
« Reply #1 on: October 21, 2019, 01:36:04 pm »
Alright, so don't forget to post some sound clips when you're done building that. I'm not sure all combinations will really sound different enough to justify this, but hey, why not.
« Reply #2 on: October 21, 2019, 01:54:45 pm »
actually, I'm building this whit no middle pickup since it would need an extr a 1 knob and I want to look stock but I will do that when I'm done building it
« Reply #3 on: December 01, 2019, 01:43:24 am »
so I built it and I suggest you not-to. cause most of the combinations are either off or unusable. you better just use a phase switch and maybe a series-paralel one. don't bother whit this, it's a pain
