Hello everyone,
I have an issue with my power supply/ battery management.
As you can see in the schematics I attached, I have an SDS011 connected to an ESP32 and is taking power from a step up converter that has at his heart a ME2108
that can hold max 600mA load. Thing is that ESP32 has huge spikes in current draw when I activate WIFI. This issue is non existent if I disconnect the SDS011.
So by activating WIFI + SDS011 the voltage drops in like 2-5 seconds from 5V to 0.60V. I did some debugging on the board and it seems it happens before 5V booster.
Therefore I think the issue is coming from the battery management circuit, now I have no idea how to debug further so a helping hand/mind will be much appreciated.
