Author Topic: parallel approximations  (Read 622 times)
Offline aboubkr90Topic starter
  • Country: sd
« on: January 21, 2025, 04:55:01 am »
Hello everyone!
I wrote a white paper and I need someone to review and help me refine it.
Thanks in advance.
Aboubkr Alrasheed.
Offline moffy
Re: parallel approximations
« Reply #1 on: January 21, 2025, 05:12:16 am »
If you want to patent as you stated in your PDF you shouldn't publicise before patenting, anything in the public domain can void a patent application.
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #2 on: January 21, 2025, 12:33:09 pm »
  • Country: sd
« Reply #3 on: January 21, 2025, 02:35:09 pm »
Seems so.
But why are they using it for 100Msps?
With current fet latency, this thing can easily do 100Gsps!!
Offline tggzzz
« Reply #4 on: January 21, 2025, 03:01:13 pm »
Seems so.
See Keysight and LeCroy scopes. Also check the prices, and probably export regulations.
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #5 on: January 21, 2025, 03:08:52 pm »
One reason already said by tggzzz - prices and export regulation.
Another drawback of such a design is that errors grow exponentially with each stage. Therefore, a very precise scheme is required, and this is the reason why the pipeline architecture uses not 1 bit, but 3-5 at each stage, and why its width is limited.
  • Country: sd
« Reply #6 on: January 21, 2025, 04:01:28 pm »
I kept reading the article.
That's completely different.
The term "stage" in pipelined ADC is an ADC.
Here I'm talking about a single ADC with propagation between stages that are simple differential couples with Schmitt trigger outputs.
Bit error in this design happens when the stage to stage delay is a considerable portion of the input signal. Which is also completely different to the bit error in pipelined ADC.
  • Country: sd
« Reply #7 on: January 21, 2025, 04:03:58 pm »
They're pipelining ADCs in series.
I'm talking about operating ADC stages in parallel.
Online mawyatt
« Reply #8 on: January 21, 2025, 04:21:47 pm »
If you want to see the SOTA in ADCs today (well back in ~2010 when we were still involved), check out the Non-Uniform-Sampling ADC (NUSADC) championed by Dr Mike Chen @ USC.
This technique makes the most use of a small number of voltage parallel comparators and takes advantage of advanced CMOS scaling by digitizing the precise time the input voltage crosses a comparator threshold, thus digitizing the input in both amplitude and time. This unique technique (amplitude and time digitizing) allows Post ADC conversion Anti-Aliasing Filtering in the digital domain.
Best
~Wyatt Labs by Mike~
The following users thanked this post: pardo-bsso
