Hello all, I am having an interesting problem, and cant seem to figure out whats going on. I am designing a circuit (arduino clone that powers a small or large dc motor, schematic attached) that uses a dc/dc buck converter (digikey part# BP5277-50-ND). When I'm powering the device with my bench top power supply, or an isolated power supply I have no problem. However once I use a Mean Well GS160A24-R7B power supply (24V 6.67A 160W Max) it destroys the buck converter! The only thing I have noticed is that when I use my fluke to check polarity, the ground output of the Mean Well power supply is connected to mains ground which tells me its not a isolated power supply. I'm going to switch to a isolated power supply, but I would still like to learn why this would break the buck converter.
Any help would be greatly appreciated!
-Jim
