Hi everyone,
I am very much fluent in digital electronics, but I have to admit I am no expert when it comes to power supply design, so I could really do with some assistance please.
I am trying to create a PSU that can convert 6.3VAC into 3.3VDC @ 1 - 1.5amp
I bought a bunch of ebay/China buck converter modules (more for experimentation with different chipsets so I can later integrate the buck convert of choice into my pcb)
So I moved my design onto the bench and used a Variac to generate the 6.3VAC for convenience. This is fed into a bridge rectifier, and a 15,000uF filter capacitor is placed in parallel with the bridge rectifier to give a smoothed DC output.
I hooked up the load tester and scope and applied load and the ripple varied as expected within reasonable limits with load variations. All fine so far!
I added a linear 3.3v regulator and connected the load to the output. The linear regulator worked as expected and provided a near enough perfectly smooth 3.3v. Again all fine.
I replaced the linear regulator with the first buck converter module and applied load. The peak-to-peak voltage on the output of the regulator is terrible, even with low (100ma) loads.
I wound up the variac to a higher voltage to give more headroom for the buck converter to operate, but still the same problem.
I tried a different buck converter, but still the same problem. I tried another, still the same! I tried adding a filter capacitor to the output of the buck converter, still the same!
So if we look at the waveforms, we can see I am getting 50hz ripple on the output of the buck converter. Why is this happening? If there is enough headroom in the smoothed DC from the bridge/capacitor than I didn't expect this ripple to occur.
Here is one example scenario on the scope (attached to this post)
Pink is the AC from the variac
Yellow is the smoothed DC (12.7vrms 960mv ripple)
Blue is the output of the buck converter (3.24vrms 800mv ripple!)
As you can see the ripple in the output lines up perfectly with the 50hz AC and the 50hz dipping of the capacitor during charging cycles. Why is this 50hz appearing on the output when there is so much headroom from the smoothed DC?
So as this is not what I am expecting to happen I must be doing something dumb. I would appreciate it if someone could point out what dumb thing I am doing
Thanks in advance
