Many years ago I used to work in such things for a pollution analysis company. We had many things made by Horiba, Thermo Electron and others.
One device we had, and I can't remember who made it, was a device like you're describing.
A know volume of air was sucked into a chamber ( over time T) with a laser at one end and a PMT at the other and that chamber had a high density coil wound around it that created a rotating magnetic field. This caused the sample to rotate and thus if a particles reflection went from a dot to a line and back in 360deg rotation it was considered a fibre and so dots and fibers could be counted per rotation and volume within T. Rotation also allowed lumpy particles to be seen easily.
It was portable in a small suitcase and was very popular for use in brown coal mines given its fibrous nature.
We had other particulate counters such as one that had a reel of filter paper about 1inch wide. A radio active source below the tape and a counter above it. First the tape was irradiated for time T and then that portion of the tape was moved into a clamp where the air sample was sucked through the tape for time T, and then the tape moved back to be re irradiated for time T and the difference between before and after gave you your particulate count per cm3.
To do this right you need to control your air flow so a known cm3 or so pass through whatever is doing the measuring so you can extrapolate that to m3 etc.
Also dependent on the particle or fibre some are more reflective than others so amplitude of the reflection is not a good measure of particle size.
And.. I just found this link to a similar device for asbestos monitoring...
http://www.opticsinfobase.org/oe/fulltext.cfm?uri=oe-21-9-11356&id=253224
that illustrates magnetic rotation and particulate discrimination of the sample.
cheers
