Author Topic: Parallel RGB to MIPI  (Read 1184 times)
Offline CTCLTopic starter
    • CTCL
« on: February 02, 2025, 08:14:25 pm »
I have been going at this for several months now. I am still quite new to the field, self-taught, and I am learning this as I go. I am trying to come up with a design where a MIPI DSI display is driven by the Sunplus/Tibbo SP7021 SiP (System in Package) that has an HDMI and parallel RGB output. The display being used is the Tailorpixels TOH323XVT-01C https://tailorpixels.com/product/3-23-inch-bar-amoled-with-on-cell-touch-262x928-mipi/ that has a resolution of 928x262 and appears to have a single lane MIPI DSI interface.
Options, available to individuals, for converting RGB to MIPI DSI are very limited from my experience. I contacted Toshiba about getting more information about the TC358778XBG RGB-MIPI bridge IC months ago but I never got a response. I have seen some options from Solomon Systech and Analogix, though sourcing such components at such a small scale does not seem to be possible. I recently came across the Rockchip RK628 series where the RK628F and RK628D are available on LCSC as of writing, though like other Rockchip ICs, documentation is limited.
Another option I explored is to use an FPGA though the only MIPI DSI transmitter IP I could find was this from GitHub: https://github.com/skatanik/dsi_controller.
The third option I thought of was to use an STM32 microcontroller with a MIPI DSI transmitter like the STM32F469AE that would be dedicated to driving the display. This may be the most complex option where I may have to consider external SDRAM, DMA and communication between the SP7021 and the STM32.
Offline sd
Re: Parallel RGB to MIPI
« Reply #1 on: February 02, 2025, 09:46:44 pm »
Csdn.net might have more info about the RK628. If you find something, you can use baidudownloader to get the files (for a small fee).
If I recall correctly, GOWIN has free (for their FPGAs) MIPI DSI IP.
The following users thanked this post: CTCL
