in my meters i put 3 amps fuses only, they are rated at 600volts
But Keysight says 3 amp for the front panel and 7 amp for the inside one if i recall ... witch i find stupid
I'm not using the sand filled ones, but i should in case of an overload, BUT for higher currents i work in voltages and shunts, instead of current, i never blow the fuses
And the sad thing is, when the meter is calibrated, they normally put stickers on the case screws ... i asked them to put the stickers on the top casing, rear position.
