Author Topic: PC pin / socket receptacle manufactures  (Read 144 times)
Offline b177Topic starter
« on: January 24, 2025, 06:46:50 pm »
I am looking for alternative MFGs to MillMax PC Pin / socket receptacle, specifically series 8369.
https://www.mill-max.com/products/pin-receptacle/receptacle-with-standard-tail/8369
This part, the socket accepts 1mm diameter pin, and has a 0.76mm tail. I have combed through DigiKey and Mouser for Manufactures and review all of their offerings. The closest I found was Preci-Dip, which is generally lower cost than MM, but they do not have sockets that accept 1mm pins.
I've also looked at LCSC, hoping to find a lower cost Chinese brand but didn't find anything.
Any suggestions / leads / places to search, etc?
Thank you in advance.
Online henmill
Re: PC pin / socket receptacle manufactures
« Reply #1 on: January 24, 2025, 07:03:30 pm »
Have you tried Harwin? They make a lot of similar receptacles to Mill-Max. Might be pricey though.
https://www.harwin.com/products?family=sockets&range=ezi
