Author Topic: Switching controller that goes above and bellow Vin?  (Read 3055 times)
Offline KorkenTopic starter
« on: May 09, 2013, 02:43:46 pm »
Hi all!
I've been working on a PSU where I need a switching controller that can with one inductor go above and bellow Vin.
I've been searching night and day but I'm unsure of what this type of switching controller is called so I'm unable to find one on Digikey.
Could someone help me with a push in the right direction? :)
If possible I'm looking for one with internal witching transistors and one with external.
Regards, Emil
Offline oPossum
Re: Switching controller that goes above and bellow Vin?
« Reply #1 on: May 09, 2013, 02:51:49 pm »
SEPIC: Single ended primary inductor converter
Offline aep9690
« Reply #2 on: May 09, 2013, 02:52:26 pm »
I think you are looking for a buck boost converter.  It can either boost a voltage above VIN or buck it down below.  They are typically used for uncertain input voltages but I think it will work for what you want as well.
http://en.wikipedia.org/wiki/Buck%E2%80%93boost_converter
http://focus.ti.com/paramsearch/docs/parametricsearch.tsp?family=analog&familyId=753&uiTemplateId=NODE_STRY_PGE_T
There are also other solutions such as SEPIC or Cuk converters
