Author Topic: SOT23-5/6 SOT553 opamp most common?  (Read 1809 times)
Offline MTTopic starter
  • Country: aq
« on: July 10, 2018, 12:54:11 am »
Which +/-5V min supply , SOT23-5/6 SOT553 opamp are the most common , cheapest and always easy to get?
Looking for "the 741 etc" in SOT packing.
Thanks!
Offline ahbushnell
Re: SOT23-5/6 SOT553 opamp most common?
« Reply #1 on: July 10, 2018, 01:59:32 am »
Thanks!
Ncs7101sn1t1g on semi
Sent from my SM-G930V using Tapatalk
The following users thanked this post: MT
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: July 10, 2018, 03:38:19 am »
Hmm, I seem to have more than a few OPA170/171, but that may be more precision than you were looking for.  TLV2371 is more that speed.
Seven Transistor Labs, LLC
Offline IDEngineer
« Reply #3 on: July 10, 2018, 08:11:19 pm »
Go to DigiKey.com, opamps, specify your desired package and supply rails, then inverse sort on "Quantity Available". The first few results will give you a nice snapshot of parts that are consumed, and thus stocked, in high(er) volumes. From there you can drill down to additional criteria such as performance and cost.
Offline Zero999
  • 0999
« Reply #4 on: July 11, 2018, 09:47:30 am »
The LM321, a single LM358/324
http://www.ti.com/lit/ds/symlink/lm321.pdf
Offline T3sl4co1l
« Reply #5 on: July 11, 2018, 10:06:21 am »
Ah yes, they did make that in SOT:
https://www.digikey.com/product-detail/en/texas-instruments/LM321MFX-NOPB/LM321MFX-NOPBCT-ND/3440175
The ON Semi version seems to be the cheapest at DK right now.  There's also the ST version,
https://www.digikey.com/product-detail/en/stmicroelectronics/TS321ILT/497-4061-1-ND/720981
Assuming, of course, you don't mind all the quirks that this old amp has. :)
Offline Kleinstein
« Reply #6 on: July 11, 2018, 04:21:58 pm »
With the LM321 it's not just the normal quirks of an old OP, it is also the extra supply current of the 2 nd unused OP. Inside its more like an LM358 and thus the same no load supply current.
Also don't confuse the LM321 with the old LM121 - that is a totally different (now obsolete) chip.
Offline larsdenmark
« Reply #7 on: July 11, 2018, 06:51:44 pm »
How about the LMV321 and its friends? Are they considered modern?
Offline 001
  • Country: aq
« Reply #8 on: July 11, 2018, 08:17:19 pm »
what is 'modern' for common opams?  :-//
  • Country: aq
« Reply #9 on: July 12, 2018, 02:01:49 pm »
1: I have downloaded your proposals and now studying these!
2: I have gone to Digi and done an inverse a search and now studying the result!
3: I have noted the warning of quirky opamps in new packing!
4: Had at first thought of OP171 but was a bit expensive (for the electrical function) at Distrilect.
At first i pondered if 071 was available in SOT but no, which would had fitted the bill. I need the Gbp but not much gain.
I thank you all for your suggestions and hints!
« Last Edit: July 12, 2018, 02:26:30 pm by MT »
