here I am, thank you all for your support.
thanks janoc, I believe I will make the 5Vs go well
When you're done I would love to see a picture of you holding that thing on your ear and making a phone call. Please. I'm really curious.
I know, it's ridiculous, it's as big as my head, but honestly I don't care what people think ...
Meanwhile here I am wishing someone would make a midrange smartphone a bit smaller than the iPhone SE I have, 3.8" would be just about perfect......
about the battery, just take a smartphone with a big battery ......
I never take smartphones with less than 5000 Mha, before I had a mediapad X2, and it lasted 2 full days, this lasts almost two days .. and it has 5100 Mha.
Why this obsession?
I use it as a game, for work, to see emails, to browse online, to watch videos on youtube, to read, watch movies and play pubg or similar, ...
I don't want to go around with a smartphone and with a tablet as many do, I want a single device with which to do everything. I'm already used to this, since the X2 mediapad I had before was 7 inches, now I have taken this and I am fine.
Of course if you don't need any of that, for you even a Nokia 3310 will be too much.
ok, I found the switch that's right for me, I order the PCB to be milled and I also have the USB C-type plugs, I also found the right LEDs, I just need one thing...
I want to use this piece of strip:
this strip goes to 12V, there are these resistances: 151 format 1206, they are 150Ω, 0.25W
According to a simple reasoning
I instead feed them with 12V, i have to feed them with 5V, i just replace the resistors, with these from: 62Ω, 1206, 0.25W.
quite right ?
I made:
12V - 58% = 5.04V
150 ohm - 58% = 63Ω
So I want to put these:
SMD 1206, Panasonic 62Ω, 0.25W
and I should be able to feed the strips with 5V, right?
