I don't see any problem with that layout, 32 kHz is low frequency.
The major issue with the 32 kHz crystals is excessive drive power, it should normally be below 1 uW (yes, microwatt), which is the reason for the large series reistors you'll see in many oscillator designs.
But if the oscillator IC is already optimized for this, it's OK.
