hi
I designed a small array. I'm using a 24V 4A AC/DC adapter as a power supply. The array is series parallel 16x4 and uses 64 880nm, 5mm, discrete LED's and 4 1/4W, 1 ohm resistors. I used a test light on the array and found that the brightness from one led to another was different. The positive end of the array is brighter then the negative end. What is causing the brightness to change.
I thought maybe the voltage being supplied was to low so I changed the array using the same 24V adapter for power. The array is series parallel 12x4 with the same LED's but using 4 each 1/2W, 82 ohm resistors. I got the same results.
Both times I used the series parallel wizard to design the arrays.
What is causing the brightness problem?
Rick
