yeah, with a higher voltage you can run steppers WAY faster than at there rated voltage, to an extreme i played around with linear current limiting with some TO220 transistors i had on hand, and a normal may speed of ~300 RPM at its 12V rating was 1400RPM at 76V, (yes, one transistor per coil leg and those transistors where glowing hot),
I would say wire in parallel, and use your driver to do current limiting, or you will burn it out,
