Author Topic: PCB micro-USB connector with some vertical clearance  (Read 1225 times)
Offline djacobowTopic starter
  • takin' it apart since the 70's
« on: May 23, 2019, 01:26:44 am »
Hi All,
I'm used to using micro-USB connector on my boards that work fine when mounted at the edge. They are very low profile and as long as the connector is on the edge, the fact that the mating USB cable has a large rubber housing around it is not an issue.
I'm trying to design a board now where I have to put the USB connector "inboard" from the edge, and am trying to find a connector that will work. A "vertical" connector could work, but even better would be a horizontal connector that has just a few extra mm of clearance height off the board. Searches on Mouser have not been fruitful so far.
I know this is a strange need. Maybe too strange?
Offline thm_w
  • Non-expert
Re: PCB micro-USB connector with some vertical clearance
« Reply #1 on: May 23, 2019, 02:11:33 am »
So, why does it have to be inboard from the edge.
I assume you can't route out that edge to allow the mating connector to reach the connector right?
You can see a big list of connector here, I dont see any that are lifted up: https://www.aliexpress.com/item/32919252236.html
Vertical does exist: https://www.aliexpress.com/item/32994957006.html
This one has a very slight raise, probably not enough: https://www.mouser.com/ProductDetail/Molex/204926-1103?qs=55YtniHzbhBOQihiQOeiLg%3D%3D
Daughter board to raise the connector up is another option (with through hole or castellations).
« Reply #2 on: May 23, 2019, 03:36:29 am »
This board is mean to be decorative; it's part of a holiday ornament. The connector at the edge would spoil the aesthetics with a wire hanging out the side, visible from the front.
Offline zitt
    • Pinball-Mods.com
« Reply #3 on: May 29, 2019, 10:40:27 pm »
I had a similar issue; mainly because my pcb need micro usb in the near center of the board.
I went with a molex vertical usb connector with thru hole tabs ... as I HATE when any SMT connector rips from the board during debug.
https://www.digikey.com/products/en?keywords=micro%20usb%20vertical
( https://www.digikey.com/product-detail/en/molex/1051330011/WM10134CT-ND/4356669 )
« Reply #4 on: May 30, 2019, 03:03:45 am »
Thanks. I'm going to make a footprint for this one. I found another one, from Wurth that costs about 2x as much from legit places, though I did find it a sketchier places like Ali for much less. That one is all TH, pins and studs. I think I'd like this semi-SMT one better.
Offline Kasper
« Reply #5 on: May 30, 2019, 03:42:50 am »
Thats a good pick. I use that or similar but with circular holes instead of slots
Offline zitt
    • Pinball-Mods.com
« Reply #7 on: May 30, 2019, 06:07:59 am »
Here's my micro usb USB footprint if it helps anyone. Eagle 7.5+
