Author Topic: PCB Mounting with electrical connection and vibration dampening  (Read 237 times)
Offline LasPet
« on: February 03, 2023, 08:28:00 am »
Hi!
I'm trying to find a way to mount PCBs onto a metal plate in a good way that ideally accomplishes two things:
1) Provide electrical connection between the PCB mounting holes that are grounded and the metal plate the PCBs will be mounted upon.
2) Provide some vibration dampening for when the machine is shipped.
Do you know of any mounting method/mounting component to accomplish this? Most PCB standoffs I've looked at accomplishes only one of the two criteria.
Offline Haenk
Re: PCB Mounting with electrical connection and vibration dampening
« Reply #1 on: February 03, 2023, 10:02:46 am »
star washers and silicone HDD mounting dampers like
https://www.amazon.com/Akust-Hard-Drive-Vibration-Screw/dp/B00ZH8DXPY
not perfect, maybe add some flexible grounding wire just to be on the safe side...
