Hello all,
I'm working on creating really tiny PCBs (11x10mm) and I wanted SMD pins on the edges of the PCB like the ESP-12 module has. How does one go about designing a PCB like that in the design software(I use EAGLE), and how exactly do you place the order for such PCBs? From what I've read, you have to create a PCB panel and then break them once is manufactured, but how do you add the break marks, plated holes and copper pads on the edges in the design software and instruct the manufacturer what I expect?
I've attached a sketch I made showing what I wanted to do. Thank you for your time!
