I’m looking at 4 layer PCB design. I’m going to have a 400 V signal between layers 1 and 2. This signal is going to be swinging between 400 V and 0V at 100 kHz. As shown below
I was wondering if anyone could recommend a layer stack up to help avoid the prepreg breaking down
I know that the breakdown voltage of the prepreg is 30-40 kV/mm however this is not the only parameter to consider. I’m also worried about the switching frequency and the fast switching edges as I'm switching a square wave. As far as I know this will "derate" the distance
I only have a small copper area (~10 mm by 5 mm) that is actually this switching node as seen in the image below the read area marked by yellow dot however I'm assuming this still needs to be taken into account as I don't want the prepreg breaking down.
I want the distance to be as small as possible to reduce the inductance between the 2 layers but at the same time I want it to be enough as to not breakdown the material
Could you help with recommending a layer stack up or a minimum distance between layers 1 and 2?
Best Regards,
Glenn
