Author Topic: Can anyone explain the details of what I'm seeing on this pressure sensor die?  (Read 777 times)
Offline yelneergTopic starter
This came out of a malfunctioning pressure sensor in a SCUBA diving computer. From the research I've done I'm pretty sure it's a Wheatstone bridge composed of piezoresistive elements. Can anyone give me details on why this is laid out like it is and what the process is for building it up? Does the square bit in the middle constitute the bridge?
Album: https://imgur.com/a/fNGvIrs
Online CatalinaWOW
I am sure the square is not the bridge.  The bridge is usually small serpentines that wouldn't show up well compared to the metalizations seen in your picture.  The other contacts are consistent with bridge connections in these sensors.  Google will give you several hits on ways they can be constructed, though I haven't seen anything specific on SMI's method.  My best guess for the square is a shield, or perhaps one electrode of a capacitive sensor for the motion of the diaphram.  They would then combine the results with the bridge output for better dynamic range or better accuracy or redundancy or who knows.
