Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
PCB trace impedances of integrated circuits with high input impedance
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: PCB trace impedances of integrated circuits with high input impedance (Read 568 times)
electronx
Regular Contributor
Country:
on:
May 13, 2024, 12:18:38 pm »
There is an ADC front end IC (opamp) at the input of my ADC card and it has high input impedance, What should I set the differential trace impedance to when drawing the PCB? Does this matter much?
Last Edit: May 13, 2024, 12:20:42 pm by electronx
Logged
moffy
Super Contributor
Country:
Re: PCB trace impedances of integrated circuits with high input impedance
Reply #1 on:
May 13, 2024, 01:01:43 pm »
For a 0-20kHz frequency range the trace impedance is not an issue, but if you have to run them any length keep them close to one another to reduce differential pickup.
Logged
shapirus
Super Contributor
Country:
Reply #2 on:
May 13, 2024, 04:10:34 pm »
It depends on the speed of the signal (edge rise/fall times), source impedance, and the length of the traces between the source of the signal and the ADC.
What numbers are you dealing with in terms of the above?
Last Edit: May 13, 2024, 04:12:19 pm by shapirus
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
