The Equivalent input noise voltage of LMV321 is listed as 39 nV/sqrt(Hz) at 1 kHz, which is on the high side. Very cheap "audio" opamps typically have less than 15 nV/sqrt(Hz), and better ones have less than 5 uV/sqrt(Hz). E.g. NE5532 or RC4580 or LM833 - inexpensive, decades old designs commonly used for audio - all come in around 4.5 nV/sqrt(Hz). Some of the best designed by National Semi (and mostly cancelled by TI) were ~2 nV/sqrt(Hz).
The open-loop gain is also a little on the low side. This is in line with the distortion figures in the datasheet, which are not great: no better than 0.01% THD+N at unity gain, and worse with gain. This might not sound like much, but most opamps for audio are at least an order of magnitude better, and the best of them are three orders of magnitude better (0.00003%)
The above doesn't mean that they won't work for audio, they will of course. You will need to determine for yourself whether the performance is adequate. "Audio" is a broad category; are we talking about Hi-Fi or an intercom system or ...?
